Question about Acer Aspire 5315-2153 Notebook
Fan how can I check to see if my fan is running?
  • 157 Answers
It is simple you can use hands and feel the air if exhausts is working good then it means your fan is running well.
Posted on Jul 23, 2013
My coolin fan wont come on wat should I do
Cooling fan is controlled by a relay and a temp sensor. You need to check that each piece is working.
Run power to the fan. fan run? fan ok.
Bridge the relay. Fan run? run power to the relay coil. Fan run? relay good.
find temp sensor. replace.
May 29, 2015 | Cars & Trucks
Tip
Suzuki Grand Vitare 2.0l. How to check why heater fan is not running
If the heater fan is not running;
1. Check the fuse first of all.
2. Check if the fan is running when connecting 12VDc directly to the fan.
If not running . Replace Fan.
3. If Fan OK - check the voltage on the connector from the fan between red and Black wire. Must be 12V
If no 12V - Supply voltage is missing - probably fuse defect.
4.If 12V = OK - measure the voltage on the Violet wire in the connector.
When button on dashboard is set to "Fan active" You must measure a voltage here close to 10VDc. If OK Fan Resistor/Regulator defective.
5 If no voltage (10V) on the wire (violet) when set to "Fan active" controlboard behind the dashboard defective.
on Jan 31, 2011 | Suzuki Grand Vitara Cars & Trucks
How do you check a fan motor
You need to check the volts at the motor while it's running, to make sure some safety is not shutting it off. Then check the amps on the motor while it's running. Also you need to check your capacitor and wiring.
Apr 30, 2014 | Heating & Cooling
My cadi 1988 is running ruff and quit running feels like over heating but no leaks, just smells
REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP.MAKE SURE COOLANT NOT LOW.IF ALL IS GOOD CHECK FOR LEAKING WATER PUMP WEEP HOLE IF LEAKING REPLACE WATER PUMP.MAKE SURE COOLING FANS RUNNING.IF ENGINE RUNNING HOT WHILE SITTING LONG TRAFFIC LINE AND COOLANT NOT RUNNING.CHECK COOLANT FAN RELAYS AND FUSE.IF ALL IS GOOD HOT WIRE MAKE SURE COOLING FAN MOTOR GOOD IF COOLING FAN DONT RUN WHEN HOT WIRED FAN MOTOR BAD.IF FAN MOTOR OKAY AND FUSE RELAYS GOOD YOU HAVE FAULTY COOLING FAN WIRING.YOU COULD HAVE BAD ENGINE COOLANT SENSOR OR FAULT IN ECM CODE SCAN TO CHECK THEM BOTH.CHECK ENGINE OIL.LOOK LIKE MILK SHAKE YOU HAVE LEAKING HEAD GASKET.IF OIL LOOKS OKAY.YOUR ENGINE BLOCK, RADIATOR AND HEATER CORE NEED FLUSHING.
Sep 20, 2011 | 1988 Cadillac Sedan DeVille
I got a microbus 2.3 2000 model, the fan is not working. i have checked all fuse and relays all are fine what next must i check. i did also check the wiring frm the fan to the relay ,everthing is looking...
Run leads direct from the battery to the fan and check that it runs. Check that there is power at the fan (the fan runs) when the thermostat on the radiator is shorted out.
Jan 16, 2011 | Volkswagen Microbus Cars & Trucks
No air blows out vents how do i fix?
Sounds like the indoor fan isn't running.First go to the thermostat and take the fan switch from auto to on. If there are no problems with the fan it should run. Next check your circuit breakers. If they are on, then turn off the power to the indoor unit and spin the fan by hand to make sure it spins freely. If it doesn't then you probably need a new fan motor. Next check the capacitor for the fan. They are usually attached to the fan on indoor units. If the capacitor looks swollen then it is bad or you can check it with a multimeter. If everything mentioned is good and the fan still isn't running, check to see if the fan is connected to a circuit board. If it is, set the thermostat to make the air come on and check for power where the fan is connected to the circuit board. Let me know what you find if the fan still isn't running.
Sep 26, 2010 | Ruud UBHC Air Conditioner
My camry 1993 engine is heating up while idling or in traffic also when ac is on. drives well on high speed without overheating
You have a radiator fan motor that is not running either due to a thermostatically controlled temp switch,(Located on the back of the radiator) a failed fan relay (in the engine compartment fuse /relay box) or a bad fan motor.
You can troubleshoot by checking for 12V DC to chassis ground at the fan motor temp switch. If you have power in you can jumper with a wire the switch wires and see if the fan runs. If it does not run then you need to check the fan relay and motor.
To test the fan you can run a wire from the battery to the fan and another wire to chassis ground to see if the fan runs. If after directly connecting 12V DC to the fan motor and it does not run the fan has failed.
As far as the you either replace it with another one or... have to figure out which 2 wires control the fan motor and jumper them out to see if the fan runs.
Kelly
Jun 01, 2010 | 1993 Toyota Camry V6
I have a 1999 chevy cavalier and the cooling fan will not start
CHECK COOLING FAN FUSE AND RELAY.IF BOTH GOOD SCAN CAR TO CHECK COOLANT TEMPERATURE SENSOR FAULT CODE.THE PCM AND COOLANT TEMP. SENSOR IS WHAT CAUSE FAN TO RUN AT CERTAIN TEMPERATURE.IF ALL IS GOOD.HOT WIRE COOLING FAN USING JUMPER WIRES TO BATTERY.IF FAN DONT RUN REPLACE FAN MOTOR.IF FAN RUNS YOU HAVE SHORT OR BROKE WIRE IN THE COOLING FAN ELECTRICAL CONNECTOR.
May 06, 2010 | 1999 Chevrolet Cavalier
03 Mini Cooper Power Steering Fan will not run
2006 mini cooper s power steering fan seezed. replaced with new fan won't run?
Mar 30, 2009 | 2006 Mini Cooper
Cooling fan won't come on
if you already replaced the thermostat, then check if both fans where running when the a/c on or if it is just one fan on the condenser is running. if the only fan running is on the condenser try to check the connection of the thermostat then also check the fan of your radiator if it is still running.
Mar 21, 2009 | 1998 Ford Mustang
Acer Aspire 5315-2153 Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
