Question about Acer Aspire 5315-2153 Notebook
Fan help need
My fan isn't working causing programs to stop
    New Friend:
  • 157 Answers
I think due to system heat up your power supply is not working good. So you need to call the technician to repair the power supply of your laptop.
Posted on Jul 23, 2013
50010xffffec75
dude- all the wholes in your pc closed off??? if so then your fan what is it barring or magnetic? if it is baring then you will need to replace... my guess it is.. if it were magnetic it would just stop PERIOD...the fan isn\'t spinning enough ( high enough rpm\'s) to keep a constant flow at the rate in which the CPU needs or heat sink needs....you should have a diags in or with in your bios....run those it\'ll tell you what it is at or what it should be at... you can make decision then.... if your fan isn\'t running then just replace fan. If fan is running and your diags isn\'t loaded or doesnt have the utility ...you will need to swapp the fan from a good working PC or buy a new one.. if you STILL have issue thn your problem lays with in the power supply... it is either your MAIN power supply or it is your motherboard (12v) then you will need another mother board. hope this helps!!!!
P.S. is your fan clean heat sink clean?????
May 14, 2014 | HP Computers & Internet
GE spacemaker range model number jmp28g0r1wh display goes blank and oven turns off
the model number isn't correct.check and send the model number again.if you changed the sensor this should take care of the f3 error code but the clock shouldn't go blank and oven stops.like i say your model number doesn't show up as a good number,if this machine has a fan in it you could have a bad fan motor,the fan cools off the electronics and if it isn't working the clock assy. can get hot,damage it and it will do this,also i've seen on some models there's a screen where the fan is and dust gets stuck on the screen and the fan can't blow any air,i'm just telling you what i've found before but it sounds like the clock assy. is heating up and shutting down,if there isn't a fan in your model it sounds like you have a bad clock assy.if you send the model number i can look it up for you.
Nov 15, 2011 | Kitchen Ranges
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
I am in saudiarab i have crown victoria 97 model it is working good but i have problum in air condition system when i run my car its running good no problum but when i start my air condition it is heating...
The air conditioning condenser creates a lot of heat when the a/c is on. The cooling fan is supposed to run the whole time the a/c is on to keep it cool. If the fan isn't on, the radiator will absorb this heat and cause your car to over heat. You should also check your coolant level. So, it sounds to me like your cooling fan isn't working.
Sep 13, 2011 | 1997 Ford Crown Victoria
Engine Cooling problem 2000 Jeep Cherokee 4 cyl
Although the 4 cylinder is too underpowered to have air conditioning in my opinion, it still shouldn't overheat within 10 minutes unless something is wrong. If your Jeep doesn' not overheat when you are driving WITHOUT AC on then your compressor might have a problem and causing the engine to work too hard to turn it.
But if it overheats without the AC on, then the first thing you need to do is check the cooling fan and see if it operates! There has been a lot of problems with the cooling fan relay on this model. If that isn't it, then move to changing the thermostat and checking the water pump.
Jul 03, 2011 | 2000 Jeep Cherokee
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
My 2000 galant is having high engine temp when i stock in traffic,but it is in normal range when im running. i change already the thermostat,rad cap and hoses, but nothing changes. what would be possible...
Sounds like the radiator fan isn't coming on. You don't need the fan on when you're moving, cause air is blowing into the radiator, but sitting still you need the fan or it'll overheat. This makes me think the fan isn't coming on.
Jun 13, 2011 | 2000 Mitsubishi Galant
My SerifDrawPlus X3 reboots unexpectedly after I apply image effects to an image...reads "program closing windows 7 is trying to find solution to this problem" - can you help?
This could mean your PC overheated, had a error or another problem causing Windows to force it to shut down. Is the fan in your PC working right? If it isn't working (correctly), buy a new one. If you don't know how, here's a good guide how to. If it is working correctly, a error might caused it. If so, Windows 7 will find a solution for it. Check the white flag next to the internet and volume icons. If these to are not the case, your PC might doesn't have enough memory to hold image effects and too less RAM (Memory) could cause a unexpected shutdown. Don't hesitate to ask me more! Thanks for using FixYa, and have a great day.
Jun 04, 2011 | Computers & Internet
I have a 6 cylinder Chevy Malibu year 2000 my radiator fans both stopped working what could be the problem?
if the car isn't overheating they probably haven't stopped working, they come on as needed, even if the car is turned off so always be careful when working around them, If you are having overheating problems check the fuses for the fans first
May 15, 2011 | 2000 Chevrolet Malibu
The slightest of jolts and it crashes why a new fan has been fitted some 8 weeks ago appx and it started to crash just after that ??
Verify that the person who replaced the fan correctly removed the old heatsink (thermal) compound and replaced it with new compound. Verify that the fan is connectect to power - you should hear it spin up intermittently during use, especially if you stop the Thinkpad in the Setup program when turning it on. (Pressing F2 or ENTER usually takes you into the setup program - press the key indicated on the Thinkpad screen on initial power on). The fan should be audible within 10 to 20 seconds roughly. If you don't hear the fan power-off the Thinkpad and check those two things.
Caution: Excessive heat can permanently damage the notebook computer! Don't let it run for more than 60 seconds in SETUP without a working fan because the CPU will run at 100% load while in SETUP. (It's normal behaviour though because CPU Idling isn't implemented in the SETUP program)
Apr 14, 2011 | IBM ThinkPad T41 Notebook
Acer Aspire 5315-2153 Notebook Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
