SOURCE: Kenmore dishwasher 665.1671590
Your inlet hose probably came loose on the left side of the dishwasher. If you pull the d/w out 6 inch. or so you will see the s-shaped hose going to the inlet port on the tub. Make sure it's not pinched or leaking..Catriver
SOURCE: Kenmore Ultra Wash Dishwasher
Thank you Catriver! You were in the zone! It's working like new! Many thanks!
SOURCE: dishwasher pump not working
if you go here http://www.searspartsdirect.com/partsdirect/index.action and enter your model number without any spaces you can get a parts list on that page you will see show diagram it will give you a blueprint of the pump moter assembly
SOURCE: Kenmore coldspot refrigerator
checked the pump action????its a water valve powered by 110v.se if you can rig a test cord and plug into the valve itself see if you get water then. also check to tubing leading to the ice maker for possibly being frozen, as a result of poor water flow in the first place
SOURCE: water inlet valve Kenmore dishwasher
Okay handy Mike,
First of all, is this a new dishwasher? Or, is it a used one? The reason I ask is because there should be a warranty with a new appliance and you should not have to worry, or have to pay for, any repairs.
The problem you are experiencing could very well be a water inlet valve problem (good assessment), but may also be something more simple. The dishwasher has a float inside the tub that is supposed to shut the water off, when it reaches the appropriate fill level. Check the float to make sure it moves up and down and that you can hear the switch "clicking". Sometimes small items get stuck under the float and will keep in the up (or shut off position).
For some helpful part locator drawings refer to searspartsdirect.com and type in your model number. An illustration of the water inlet valve can be found under the "Frame" heading in the next page as item number 24 (part number 154195301). The float and float switch can be found under the "Tub" heading as items number 13 (part number 154144301) and 24 (part number 5300809863), respectively.
If you require further assistance, please let me know. I hope its something simple and you don't require parts. But, if you do, you know where you can get them. If you do not wish to order on line, use the part numbers provided and go to your nearest appliance parts retailer. I hope this helps you. Good Luck.
Jeff
Hello &
Welcome to FixYa
When the
water comes however, won't go inside the unit then it indicates that the
problem is either with a clogged/blocked inlet valve or the water inlet valve
itself has gone bad and needs replacement. You can also test two terminals of
the water inlet valve before replacing it. Please get back to me if you have
any other questions.
Kevin
