Question about Acer TravelMate 2423WXCi Notebook
Connect projector regarding connection to projector
How to connect laptop to vga projector?
you need a cable. it may be the one that usually connects a computer to a monitor = depending what the input is on the projector but it sounds like an ordinary monitor cable as projector is VGA ( the other type has a digital input at one end ;but Im pretty sure thats not it.) If you have another computer set up just borrow the monitor cable and try it. There's already an input for one end in your laptop if its ok buy an extra cable
Mar 18, 2013 | Lenovo S405 14.0inch Laptop
Hi ! i have a fujitsu lifebook lh530 , but when i try to connect to a projector the term of "connect to a projector" not appear in windown 7 so i can not connect my laptop to a projector . so...
Hi
After connecting the projector ( or any other external display ), you need to tell the laptop to toggle the display to the external one, not the laptop screen.
To do that, you can press the ( Fn key + F7 ).
Some times, it's F4, regarding the laptop.
F-key have icon like monitor on it.
Please, Tell us your results.
Good Luck
May 19, 2011 | Fujitsu LifeBook A6110 Notebook
USB cable connection
the usb is usually for the remote contol pointer, you are better off using you vga port.
May 16, 2010 | Acer PD100 Multimedia Projector
How do I connect a projector to my G60
Hello
  1. Start by making sure the laptop and projector are both turned off before you start trying to make any connections.
  2. Locate the video cable -Usually your computer should have a svideo ort out. The projector should have either a hdmi or a RCA immput ports, thus you need a svieo to rca cable. Otherwise your laptop should have a VGA port oout where the projectorr should have a VGA port in.
  3. Make sure both ends are securely connected and tighten if necessary. Use a screwdriver or small pliers to tighten the connectors. A loose connection at either end will prevent you from displaying your presentation.
  4. Locate the audio cable and connect the audio cable included with the projector to the Audio Out on the laptop and Audio In on the projector. Make sure these connections are tight.
  5. Start your laptop and the projector. Make sure to check all connections to ensure they have been properly connected.
Really hope this can help you.
Kind regards
Andrea
Nov 13, 2009 | HP G60-120US Laptop
How do i get sound out of a benq cx660 projector!
Hi I am Vortash .. you need another connection from the laptop earphones to the audio in on the projector . that would be a 3.5 mm stereo jack to twin phono .. or if you have a line out on the laptop from there , if you do have this connection then you may need to activate the sound input in the menu of the Projector .
hope this is of help Regards Vortash
May 17, 2009 | BenQ PB6100 Multimedia Projector
PROJECTOR LOCKED WITH PASSWORD
hmmm...have you connected with 3M on this unit? If it's registered, they will issue you a new password.
www.3m.com
Aug 20, 2008 | 3M MP 8640 Multimedia Projector
Regarding Infocus projector connection to Sony TV
the projector does not have an rf connector, so you have to have a modulator that has rf in and composite video and audio out.
Jun 17, 2008 | Office Equipment & Supplies
USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
Jan 17, 2008 | Sanyo PLC-XU73 Multimedia Projector
Connection with the TV
It will work only if your TV has a Video OUT either in Composite RCA, S-video or in some other form although not all TV models have this feature.
Alternately, you can hook up your projector to an old VCR which definitely will have a Video OUT and use its built-in TV tuner. Of course you have likewise to connect a cable/aerial to the RF IN of the VCR.
Hope this be of some help/idea. Good luck and kind regards.
Dec 03, 2007 | Dell 2300MP Multimedia Projector
Acer TravelMate 2423WXCi Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
