Question about Minolta bizhub 200 All-In-One Printer
Error c3452 i get an error c3452 on my bizhub 215 photocopier
  • Minolta Master
  • 6,696 Answers
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 15, 2015
2 Suggested Answers
firecontrol7
  • 6696 Answers
SOURCE: error C3452 right after power on.
I assume this is a Bizhub, Fusing unit fault. to clear you will need to look on the right side of the machine, if this machine is networked?, just below the scanner, on the right side is a small cover it will come off close to where your network cable goes. once it is open press the small black button (Looking at the machine from the right side it will be on your left using a paper clip or small screw driver just gently depress the button the machine will go thur its cycle you will get a Trouble reset on the screen with a "OK" touch then power off, wait ten seconds then power on
Posted on Aug 02, 2009
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
How do I fix error message C3452?
It is most likely your fusing unit. Part number 9J06 R706 00 .
If you have had any power surges recently, meaning lightning struck your building and something else was hit. It could be the main board. You need to put a surge protector on this machine either way.
Oct 03, 2014 | Konica Minolta Office Equipment & Supplies
How to rest a C3452 error code on a minolta C300
try a trouble reset turn the machine off hold utility/counter power machine on select trouble reset reboot machine
Aug 17, 2014 | Konica Minolta Bizhub C300 All-In-One...
Error C3452
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
Error c3452
error c3452 is fusing warm-up failure.
first do trouble reset.
second, check H1 or H2
third, check TH1 and TH2
four, change new fusing unit
five, change PU
six, change PWB-A
Sep 14, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 200 has error code c3452
Sir/mam check the right side door that you open to remove the image unit check that the two latches that hold the door close are OK especially the rear one. Close up. To reset. On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover with the machine on use a small screw driver and gentle depress the small black switch the machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. Code will come back but now press the Utility/counter button should see button that say maintenance mode press that see trouble reset press that machine again will go thru warm up procedure will see the "." DO Nothing! Should go to "Ready to Copy" if the code comes back have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. Can catch on fire! That will ruin a perfectly good day!!!!
Jan 23, 2012 | Minolta bizhub 200 Copier
How and where to solve /fix error code C-D301 on bixhub c250
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
Dec 06, 2011 | Konica Minolta bizhub C250 All-In-One...
Error code c 3452 on ineo 250+
develop ineo 250 machine error comes c3452
how i solve this
Nov 21, 2010 | Konica Minolta Office Equipment & Supplies
Minolta bizhub 200 All-In-One Printer Logo
374 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
