How to reset the channel lock code - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
What is the brand name to your TV. Provide more details please.
Posted on Jul 23, 2013
How to disabled key lock on ultra samsonic television
Hi, I don't actually know how to unlock your specific TV. But here is a basic guide to unlock your tv.
    1)Turn on the TV and grab the remote.
    2)Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This should unlock the channel. This is an option for people who want the TV to stay locked out, want to be able to bypass the lock to watch a certain show or channel. All others channels will remain locked and the TV will fully lock when it is turned off.
    3)Unlock all of the channels on the TV by entering the factory reset code. There are 3 main reset codes that TV Manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will factory reset the TV.
    4)Call the technical support service number in your owners manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure you have the model number and the serial number.
    5)Or take it to a TV repair shop.
How to Unlock TV eHow
Dec 27, 2015 | Ultra Computers & Internet
Unlock tv menu
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
May 15, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
Want to reset the v-chip on my 2001orion tv model # 1933
Omni TVs have a child lock that allows parents to prevent children from watching specific channels or television shows with certain ratings. To activate or deactivate the controls, you need the four digit pass code. If you forget the pass code or if the lock gets set accidentally, you can still unlock the TV.
• Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
• Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
•Take your television to a TV repair shop if you are still unable to unlock the TV. The problem may be with the wiring, so the repairman may have to rewire the TV
Aug 12, 2012 | Televison & Video
Hi lt40fh jvc how do i get the channel locks off please
Hello
If you forget the Lock Code, a new code may be set using the steps listed below.
After a power interruption you must reset the Lock Code
Channel Guard and V-Chip settings are protected by a four-digit Lock Code. Your TV comes pre-set
with a Lock Code of "0000". You may change the code to any four-digit number you wish. To
change the Lock Code, follow these steps
Press the MENU button
Press "UP" or "DOWN" button RESET LOCK CODE
Press RIGHT or LEFT button to operate
The Lcck Icon appears.
Press ZERO to access the Lock Code
The first digit will be highlighted
Press RIGHT or LEFT button to seelct the number.
Press UP or DOWN BUTTON to move to the next digit
Continue to follow these directions for all four numbers
Press UP or DOWN button To FINISH
Press RIGHT or LEFT button to save settings and exit
Your new Lock Code is now set.
OK.
Dec 28, 2010 | JVC AV-27230 27" TV
Need instructions to unlock channels. No lock code was put in and some channels are locked and say we need the lock code?
Try 0000 or try 7777.
If one of these codes work, you will asked to reset the code.
Reset the code but do not use 0000 or 7777 as the new code.
Good Luck.
May 17, 2010 | Televison & Video
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Kids locked up the TV, need code to unlock it.
Try this: press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
Apr 21, 2009 | Jensen JER-323 Remote Control
How do you reset a locked out channel when the code is forgotten?
Try pressing simultaneously the QV and 9 on the remote to bypass the parental lock. Then press the MENU button and go into the menu to turn the lock off. At least this is how it works on several other old Mitsubishi televisions. I don't have anything on ***********'s model, but this is worth a try. I hope it works for you.
Nov 12, 2008 | Mitsubishi Televison & Video
Locked out, channel or child lock how to re-set
I know one code please try if it helps 1 press mute button once on remote control handset. 2 once again press &HOLD remote hand set mute button. 3 while keeping mute button pressed press menu button on tv set. good luck
Sep 17, 2007 | Toshiba CF36G40 36" TV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
