M729blu Connect pc and flash drives
Feature requires removable media floppy disk usb flash drive please insert connect
This sometimes happens when you want to add, modify, or uninstall a software and the process requires the presence of the original media. No media , no modification.
Dec 08, 2013 | Computers & Internet
Transfer pictures to a flash drive
From the memory of your camera which is a SD card you must transfer using the linking cable to your PC or by inserting the SD card to the card reader on the PC. Now transfer the images to a marked folder and then connect the flash drive, now copy the folder to your flash drive. Using copy and paste or send it to the flash drive using right click .
Jul 23, 2011 | Cameras
I have a Lacie mosKeyto 8GB USB Flash Drive. When it it inserted into a PC it just does not show up at all, meaning computers do not detect it. What can I do? thanks
hi have you try connect it to other computer? if is working i guess your usb port have problem try to connect your flash drive to other usb port at the back your cpu. if not working your usb flash drive have problem. thanks
May 28, 2011 | LaCie MosKeyto - USB Flash Drive - 16GB...
We are converting from a PC to an iMac. We backed up all files to the flash drive which is a NTFS format. I soon discovered the MAC is not compatible with it and I cannot transfer my files. It seems...
The MAC can read PC formatted USB flash drives BUT the USB flash drive MUST be formatted in FAT32 not NTFS.
I have a MAC and I also transfer photos from my PC to my daughter's MAC notebook.
You can also transfer files from the MAC to the PC using these FAT32 formatted USB flash drives.
Mar 13, 2011 | Western Digital Passport 320GB External...
How can I put microsoft office ultimate 2007 on a notebook computer with no drive?
These are possible solutions:
1. connect an external/portable dvd drive to the usb port and you can run the installation cd from that drive.
2. copy the installation cd to your usb flash drive and install it from your usb flash drive.
3. connect your notebook to another pc within a network and share the dvd drive of that pc and run the installation cd from there.
Sep 09, 2010 | Computers & Internet
What to do if cant find flash drive icon in my computer
Try to connect the Flash drive on to a different USB port. if still the issue persist try to connect the drive on to a diferent computer and see whether it works or not. if it works than the flash drive is fine,
Power on the PC. go to the device manager. Under USB controller check for USB ROOT HUBS . simply uninstall all the USB ROOT HUBS . than do a BIOS UPDATE. Restart the computer. than try to connect the drive. it should work out.
And if the Drive does not works on the other PC than simpl replace the flash drive.
Jul 10, 2010 | Compaq Presario M2000 Notebook
My system didn't regonize the flash drive
If it in't detecting the flash drive.....Then the driver must have been corrupted....so just uninstall unknown device....and try to connect te flash drive
Mar 15, 2009 | Acer Aspire T120 PC Desktop
Re: flash drive
First thing to do is to connect the flash drive to your computer via USb port, then if the flash drive is already detected and computer is done installing the driver for it, Just double click Mycomputer icon then you should see there the flash drive, double click on the flash drive then after that you can just copy the pics from your computer and paste it to the flash drive...
Note if the falsh drive is not detected by the computer try to connect it on a different USb port and hopefully it will be detected that time...
Hope that helps..........
Sep 21, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
