Fix error c3452 from konica minolta bizhub 215
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
  • 51 Answers
whot is the error code and whot model of bizhub u have???
Posted on Aug 30, 2009
Bizhubman
  • 108 Answers
SOURCE: how to fix error c0f32
Faulty TCR Sensor
• The measurement taken by the TCR sensor (TSRS) at a
time 2.0 sec. after the main motor (M1) has started turning
is less than 5% (greater than 4.63 V).
• The measurement taken by the TCR sensor (TCRS) at a
is 19% or more (1.41 V or less).
I would start with checking the TCR sensor located on the developing unit. Make sure it isn't caked up with toner. After that I would replace the developer and then the sensor. Check the developer unit for any damage to gears and seals.
Posted on May 17, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
How do I fix error message C3452?
It is most likely your fusing unit. Part number 9J06 R706 00 .
If you have had any power surges recently, meaning lightning struck your building and something else was hit. It could be the main board. You need to put a surge protector on this machine either way.
Oct 03, 2014 | Konica Minolta Office Equipment & Supplies
How to rest a C3452 error code on a minolta C300
try a trouble reset turn the machine off hold utility/counter power machine on select trouble reset reboot machine
Aug 17, 2014 | Konica Minolta Bizhub C300 All-In-One...
Konica minolta bizhub 215 Error Code CCF01
no luck in the service manual for that one please recheck
Jul 14, 2014 | Konica Minolta bizhub Office Equipment &...
Error C3452
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
Error c3452
error c3452 is fusing warm-up failure.
first do trouble reset.
second, check H1 or H2
third, check TH1 and TH2
four, change new fusing unit
five, change PU
six, change PWB-A
Sep 14, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error c3452
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
Jul 23, 2013 | Minolta bizhub 200 All-In-One Printer
How and where to solve /fix error code C-D301 on bixhub c250
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
Dec 06, 2011 | Konica Minolta bizhub C250 All-In-One...
C3452
hi ali... the problem with your mfp is fixing uunit warm up failure... try to perform trouble reset... turn off the machine, then hold press the utility/ counter... konica minolta logo appears... press 3, type eight 0's then then tuoch "end" then touch "trouble reset"( note: dont touch other menu displayed on screen because you might get another problem.) then the machine will re-statr.....If there is an abort code, there its time for you to change the fixing unit.... ( if you know electronics try to check the heater lamp and thermostat using a multitester, check if there is a continuity inthe both ends...)
Apr 29, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
270 people viewed this question
jasbo
jasbo
