Question about Canon imageRUNNER 3570 Copier
Shirnking I am wondering if it is possible to shrink documents using the scanner. When we scan documents they come out just fine on the screen but when we print them the documents are too large and it cuts off the numbers (Which are kind of important) If I could be told if it can shrink and how to shrink without having to go through a mess of unnecissary paper that would be great. Thanks
  • 30 Answers
Most all copiers have a built-in expansion factor of about 1% to account for slop in the paper feeding. The only way to change this is to go into the lens area and move the lens so that is closer to the drum, however this might open a whole new set a problems, with borders appearing at the edges of your copies. CAUTION: It takes only a small amount of adjustment of the lens to make a noticable difference in the size of the copies. Hope that this helps. Aloha
Posted on Aug 30, 2007
SOURCE:
How to stop printable?
  1. Have Too Many Documents? - Canon.com‎
    Adusa.canon.com/imageFORMULAScannersCanon Scanner Features
  2. Document Scanner Benefits
Search Results
    [PDF]User's Guide (Downloadable/Printable Version ... - Epson
    https://files.support.epson.com/pdf/prv7ph/prv7phug.pdf Epsonmust be observed to avoid damage to your equipment. Notes contain important information and useful tips on the operation of this product. Place the scanner ...
    How can I make Acrobat stop shrinking scanned documents?? - Adobe ...
    https://forums.adobe.com/thread/602060?tstart=0
    Adobe Systems
    Apr 13, 2012 - 16 posts - ‎11 authors
    That is the way Acrobat communicates with the scanner in terms of your ... but I need the user to print only the fields onto an original form.
    Stop or Pause Scheduled Printables - HP Customer Support
Dec 29, 2015 | Office Equipment & Supplies
I'm trying to scan an A4 size sheet(document). I was getting the same size of the scanned sheet, but now its shrinked its size so that I can not getting the same size as in the sheet. Please help me...
Hi
Try the HP software rather than the Scanner itself.
HP Solution Center > Settings > Scan Settings > Scan Document Settings > make sure it is set to Scan Document as Image (no OCR) > Apply > OK.
I hope this helps.
Aug 24, 2011 | HP ScanJet 2400 Flatbed Scanner
Lines on copy's when using auto document feeder on epson artisan 800
You don't say exactly, but I'm guessing that scanning when laying the document flat on the glass (ie, not using the document feeder) you get a printout that is fine. It's only when you use the document feeder that you get the vertical lines on the printout?
Epson repair tech in my area says this is a common problem. It is due to the aging of the calibration strip (the white strip at the underside of the flat bed glass near the "home" position). It shrinks after years and can't provide correct calibration.
This is a problem only with the pages fed through the document scanner. It sounded weird to me, but the tech said he stocks lots of replacement glass and does lots of these repairs to Epson scanners.
It might be cheaper to buy a new scanner rather than get yours fixed. He said it's pretty inexpensive to do this repair, but scanners are also pretty cheap.
Good luck.
Jan 31, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Will not scan from glass but feeder will?
Using your scanner program such as PaperPort, you really have to pay attention on where the document/photo is located for scanning.
Steps
1. Click on Start, Programs, Paperport
2. Right above the Word "SCAN", you will have several options on;
a. Document or Photo
b. Flatbed or Feeder
3. Once step 2b has been selected, the M20i will scan your document per your instructions.
Note:#1
If you place your document on Flatbed but your selection on your screen says "Feeder" where do you think the scanner will look for your document? The answer is --> Feeder!!!
Note #2
Make sure that you click Accept,& DONE, other wise M20i will just sit and wait for your next command.
I hope this resolves the confusion between GLASS and FEEDER scanning.
Jun 29, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Document Type "Film" greyed out
Close Epson Scan, unplug the TPU, plug it in, turn off the scanner, turn it on, reopen Epson Scan.
Feb 16, 2009 | Epson Perfection 4870 PRO Flatbed Scanner
My Canon MP510 scanner won't scan - the printer works fine, but I can't get it to scan. It used to work just fine.
Try using your scanner from your computer, I'm using windows XP and when i go to My Computer and the printer is connected i see a section that says Scanner and Cameras, your printer should be there, click on it and follow the easy step to scan a document.
Nov 28, 2008 | Office Equipment & Supplies
Cannon MP530
Hey, so if you already have everthing else working, drivers installed and so on. Lets try scanning a document, this should work if everything is installed fine.
press start
select run
(if your using windows vista just hold down the windows key and press r to open the run menu)
type in mspaint
now that you have paint started, click File and from scanner or camera
if a document gets scanned fine, (follow on screen instructions) then we can look at optional software to scan documents, if paint is not enought.
Thanks,
Ekse
Sep 01, 2008 | Office Equipment & Supplies
Is kodak digital science 3520DP a sorting scanner
The Kodak 3500 scanner series is probably the best scanner ever made, but NO, it doesn't read anything! Think of it as a digital camera. It only takes pictures. All OCR, ICR, BAR Code, etc. has to be read by software. Your software looks at the images and pull any info that it has been designed to detect off of that image. Some older scanners had built in bar code and patch code reading, but more and more, the software now does it, usually in conjunction with a Kofax card in the PC.
May 26, 2008 | Kodak Digital Science 3520DP Path-Through...
Problem to see any document on my scanner
Is the scanner not recognised or is it Not scanning?
Is the comp recognising the scanner? If not reinstall the driver. Run scandisk on the drive where the OS is installed. Try uninstall and reinstall.
Pls check if the scanner platten is moving, it could be a hardware problem.
Feb 21, 2008 | Office Equipment & Supplies
Canon imageRUNNER 3570 Copier Logo
56 people viewed this question
Clive
Clive
old marine
old marine
Ekse
