Question about Craftsman 33 Gallon Vertical Portable Air Compressor
Victa tiller 100
Fitting belts
How to replace drive belt on victa 38' ride on mower
There are more but they are pretty much the same across the board fitting wise....Hope it gets you on your way!
May 07, 2017 | Garden
Where can I purchase forward and reverse drive belts for a Rally model D5500GR tiller? Part numbers 4833H (forward belt), 2614J (reverse belt).
That's a real common belt fits craftsman and abunch of others you purchase it at any Small equipment parts dealer my favorite is www.jackssmallengine.com Repair website, but their are dozens of others www.searspartsdirect.com Ebay and Amazon also have sellers
Apr 18, 2016 | Garden
Drivebelt routing diagram for a troybilt pony lawn tractor
oh oh big trouble...make sure you installed correctly re check ever thing is there a twist in the belt? not riding true on idler pully? correct belt?is belt cutting into guard housing any where? is the belt making howling noise? use veernier caliper to check dimensions of old belt to new belt.I once x out a drive belt with a generic one that did the same thing. my solution dont buy cheap chinese belts stick to OME belts as the chinese ones may not fit as intended.
Jul 09, 2014 | Troy-Bilt Pony Garden Tiller
Yardworks rear tine tiller Model# 217-430-500, need belt number for replacement
take the old belt with you to any small engine or lawn equipment repair shop they should be able to match up a fractional horse power belt that will fit.
Jul 07, 2014 | Mtd Garden
My tiller needs belts, and I don't know how they
Assuming you have not already removed them make yourself a detailed sketch of how the belts are routed (your owner's manual should also show how how they go back on). Remove any guards or retainers (that keeps the belts from jumping off the pulleys) and put the new belts on just like the old ones. Reinstall any guards or retainers you removed. I know this may look complicated but if you take your time and figure out which belt does what it is not all that difficult. Hope this helps.
May 21, 2011 | Briggs & Stratton Garden
I need a belt diagram for a victa ride on 18.5 hxt
Ross , What year is your Victa ? Most HXT models I know of were made by Noma and are effectively similar to murrays of the same era. If you have given up I may be interested in the mower or any 1970's Victa ride ons.
Oct 29, 2010 | Garden
Looking for a victa pro 12 ride on mower parts catalogue
what year? and if you can post a picture it can be more helpful. Victa ride ons were made by other manufacturers with Victa stickers on them.
Oct 02, 2010 | Briggs & Stratton Garden
I have a victa corvette cox made ride on mower
Being cox made I'd go looking for cox manuals for the same era. Victa just rebadged others mowers.
Nov 18, 2009 | Garden
HOW MUCH TENSION SHOULD I PUT ON THE BOLT AND NUT THAT HOLDS THE VARIABLE SPEED PULLEY ON A MTD YARDMAN.? KEEPS THROWING BELT AND WON'T SPEED UP. HARD TO PUSH PEDAL THEN BELT FLIES OFF. MODEL 604G THANK...
The bolt should be tightened to a hundred lbs. make sure the center pulley is free to move up and down, and you ahve the right belts. Avoud belts from Lowes or Home Depot od Wally world, They NEVER fit right
Sep 07, 2009 | Mtd Products Yard Machines 158CC Tiller
Replace belts
It is pretty easy to change the belts. The correct size is the problem. I bought some replacements for mine and found they didn't just quite fit. I finally got them from Troy Bilt so they fit correctly. Remove the two fly nuts to the safety shield over the belts. Next remove the cotter pin that holds the idler pully to the control shaft. This will now allow you to swing the idler out of the way so the belts can be removed. A little twisting and turning and they will come out and go back in without a problem. Reconnect the idler pully and pin and make sure it is adjusted properly for operation then replace the safeth cover. Good Luck, RAC
Apr 02, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Craftsman 33 Gallon Vertical Portable Air Compressor Logo
57 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
