Question about Garden
Honda gx 35 brush cutter stops on acceleration .is not cutting grass
    Sergeant:
  • 342 Answers
Mahjit check that the air filter is clear. It may need cleaning. You should find this by the choke lever under a plastic guard.
Posted on Jul 23, 2013
2 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: HOW TO GET BRUSH CUTTER OFF FS 55
Look at the top of the head (where the brush cutter is) find the small hole about 3/16 diameter. Insert an allen wrench or a large nail, or anything else that will fit in the hole almost the same size as the hole. While putting a little downward pressure on this "tool" turn you blade slowly by hand until you feel the tool slide into the locking slot, this will hold the blade from turning. Keeping it in this position, take a socket and ratchet on the nut that is holding the blade and loosen and remove it. THE NUT HAS LEFT HAND THREADS SO TURN IT OPPOSITE OF WHAT YOU NORMALLY WOULD TO REMOVE IT!!!!
Posted on Sep 16, 2009
Cutter deck height
Not sure what your question means. Cutter deck height is the setting you put your deck on that determines how short you cut your grass. Start out on a medium setting and see if you like the results. Sometimes the grass comes out uneven. If this happens, check your tire pressure on all tires.
Hope this helps! :)
May 03, 2015 | Garden
How do you convert the Echo grass trimmer model SRM-22ges to the brush cutting option?
There is a hole just above the grass trimming head that you can slip a screw driver into. Turn the head so that the inner and outer holes align where you can put a screw driver or other hard steel object in. Put it in there and then turn the head counter clock wise until it comes off, it may take a little effort to get it to move, but you should be able to do this with your hands. Once you get the trimmer head off, put the blade on and hopefully you still have the nut and washer accessories to hold the blade in place. You will need to place your screw driver back in the alignment hole to hold the head from spinning while you tighten the blade nut back down. Make sure it is tight, you don't want that blade coming off at ~10,000 rpm!
Aug 23, 2014 | Echo Garden
Why does mower cut out when cutter blade selected?
this is posted is cell phone section. unless cell phones cut grass now this is a miracle. please change catagory and please add make and model of mower.
Apr 25, 2014 | Huawei Cell Phones
Honda gx 670 chokes and sputters in thick grass or when goose throttle
It sounds to me like the carberator is a little dirty, drain the bowl and clean the main jet. Also while you are there check all the jets and make sure they are open not clogged.
Sep 09, 2013 | V-Twin Horizontal OHV Engine with Electric...
What is the difference between the angle cut blades and the shear cut blades on my bolt cutter?
angle cut blades have the cutter head angled at 25-35 degrees for easier insertion into tight spots. Shear cut blades are light normal scissor blades
Jan 16, 2013 | Cutter Tools
My brush cutter keeps cutting out why
Is your fuel mixed correctly.? Do you still have good compression.? Is the choke leaver stuck on.?
May 21, 2012 | Stihl String Trimmer Brushcutter Service...
I have a Simplicity Zero-Turn 20 hp 50" cut. Just recently when mowing I have "clumps" of grass all over the yard. Any idea what would cause this? Also, the mower is supposed to stipe the lawn - I have...
Hi, well you have the cutter too close to the ground, try raising it up a couple of notches.
Now as for the "clumps" on the lawn. Well IF you mean GROWING clumps, that's because the mower is dumping the cut grass in a pile, somewhat, and that's adding nutrients to that particular Patch, and it simply grows faster because it's got more "Food".
If you mean, CUT grass patches, then again your Cutter is Too Close to the ground, and it's dragging the cut grass, and then when it gets too much, it is "packeting" the cut grass, every now an again when it builds up and is left in "piles" instead of being evenly distributed, and driven into the ground, behind the mower.
Aug 25, 2010 | Garden
Can i purchase a metal cutting blade for my sovereign petrol grass trimmer 6102
Universal kits are available that will allow you to attach a brush cutter blade to just about anything that usually has a line head. The kit contains a selection of bolts, adapters, packing washers etc - you simply select the parts you need to attach the blade. The blade itself is not machine specific.
May 08, 2010 | Garden
Stihl strimmer engine runs but wont cut grass the head wont turn what cuts grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Apr 04, 2010 | Oregon Scientific Complete Carburetor for...
Engine stalls when blade is engaged
the best way to check is to run the engine with you on it then lift off the seat and see if the seat sensor is cutting off then put a bag with some weight in it and turn on the engine it should run ok if the sensor is working and lift the back box to see if the sensor works there.. the other cause could be a build up of grass in teh cutter area stopping the blades fron moving this can caus a stall if you get a hose and blast under the cutter guards and make shure the grass shute is clear for the grass to exit this may help to mine cuts out if there is a blockage here and the grass cant get out after it has been cut it builds up at the exit plates.. Hope this works AB
Sep 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
