Question about Whirlpool Dryers
Whirlpool Duet (GEW9250PW0) motor test
I'm testing the motor on my GEW9250PW0 dryer, and both the connections are reporting 1.8 ohms. The repair manual says the resistance should be 2.4-3.6/3.8 ohms and to replace the motor if resistance is 4 ohms or greater. I'm not sure what it means that my resistance is 1.8 ohms. Is my motor OK?
  • Jeff D Jul 23, 2013
    OK, I made some progress. The motor does still run if it's totally cool. The trouble is that the bearing seems to be jamming. If I give the drum a hard manual assist, it will start running for a minute or two. It then gradually slows down until everything is jammed again. I hear the motor strain for about 5 seconds and then it shuts itself off.
    Is this a problem with the motor bearings? I think it means the motor is OK electrically but that its bearings are bad.
    Sound right?
  • Whirlpool Master
  • 15,557 Answers
How did you decide to test the motor? What is the initial problem?
Posted on Jul 23, 2013
5 Suggested Answers
skrbin
  • 121 Answers
SOURCE: Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Posted on Feb 15, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
vostendorp
  • 347 Answers
SOURCE: I need a manual for
If you go to www.whirlpool.com and at the top of the page click on owner center drop down and hit manuals and literature,on the following page at type click consumer, then enter just
GEW9250 it will then give you a choice of serial numbers to pick from under the manual of your choice
Posted on Sep 16, 2010
rickead1
  • 1998 Answers
SOURCE: Whirlpool Duet Dryer GEW9200LW1. Problem: When
so you started first by checking the dryer door switch correct? then if you had a multimeter you would check that power does come in from the wall and goto the board then leaves the board and goes to the motor as well and also goes to the timer as well Do you have any error codes at all?if the dryer door switch is bad this could be why your motor is not starting please message me back with your reply Thanks again Rick
Posted on Dec 22, 2010
Whirlpool duet dryer won't heat up
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Jul 02, 2014 | Whirlpool LAB2700ML Pedestal Drawer for...
Tip
Whirlpool Dryer Various Test Procedures - Part 1
TEST #1 Supply Connections
This test should only be done after confirming proper voltage at the outlet.
1. Unplug dryer or disconnect power.
2. Remove the cover plate from the back of the dryer.
3. Check that the power cord is firmly connected to the dryer’s wire harness.
4. Access the machine control electronics without disconnecting any wiring to the control board.
5. With an ohmmeter, check for continuity between the neutral (N) terminal of the plug and P8-3 (white wire) on the machine control board. If there is continuity, go to step 6. If there is no continuity, disconnect the white wire of the harness from the power cord. Test the continuity of the power cord neutral wire . If an open circuit is found,
replace the power cord. Otherwise, go to step 6.
6. In a similar way, check the continuity between the L1 terminal of the plug and P9- 2 (black wire) on the control board. If there is continuity, go to step 8. If there is no continuity, check the continuity of the power cord for power cord’s L1 wire. If an open circuit is found, replace the power cord. Otherwise, go to step 7.
7. Replace the main harness.
8. Visually check that the P5 connector is inserted all the way into the machine control electronics.
9. Visually check that the user interface assembly is properly inserted into the front console.
10. If both visual checks pass, replace the user interface assembly.
11. Plug in dryer or reconnect power.
12. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
13. If indicators still do not light, the machine control electronics has failed: Unplug dryer or disconnect power.
Replace the machine control electronics. Plug in dryer or reconnect power. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
TEST #2 Machine Control Power Check
This test is used to determine if power is present at the machine control electronics.
NOTE: The drum light is controlled by the machine control on all models.
2. Open the door.If the drum light illuminates, then power is present at the machine control, and it is functional. Go to TEST #6. If the drum light fails to illuminate, do not assume the machine control electronics needs replacement. Several conditions may cause the drum light not to illuminate, including a bad bulb. If the drum light does not illuminate, go to TEST #1.
TEST #3 Drive Motor Circuit
This test will check the wiring to the motor and the motor itself. The following items are part of this motor system:
Harness/connection Belt/belt switch Drive motor Centrifugal switch Door switch Machine control electronics
2. Access the machine control electronics and measure the resistance across P8-4 and P9-1.
If resistance across P8-4 and P9-1 is in the range of 1 to 6 ohms, replace the machine control electronics.
Otherwise, go to step 3.
3. Check the wiring and components in the path between these measurement points by referring to the appropriate wiring diagram and strip circuit in Section 7.
4. Check the belt switch and drive motor. Access the belt switch and drive motor by removing the front panel/drum assembly. Slowly remove the drum belt from the spring-loaded belt switch tension pulley, gently letting the belt pulley down.
5. Remove the white connector from the drive motor switch.
6. Check for the resistance values of the motor’s Main and Start winding coils. NOTE: Main and Start winding coils must be checked at the motor.WINDING RESISTANCE ω CONTACT POINTS OF MEASUREMENT
MAIN 1.4–2.6 Blue wire in back at pin 4 and bare copper wire on pin 5 of black drive motor switch
START 1.4–2.8 Blue wire in back at pin 4 and bare copper wire on pin 3 of black drive motor switch. If the resistance at the motor is correct, there is an open circuit between the motor and machine control electronics.
Check for failed belt switch. If the Start winding resistance is much greater than 4 ohms, replace the motor.
7. Check the belt switch by measuring resistance between the two blue wires while pushing up the belt switch tension pulley.If the resistance reading goes from infinity to a few ohms as pulley arm closes the switch, belt switch is OK. If not, replace the belt switch. If belt switch is OK and there is still an open circuit, check and repair the wiring harness.
8. Door switch problems can be uncovered in the Door Switch Diagnostic Test; however, if this was not done, the following can be done without applying power to the dryer. Connect an ohmmeter across P8-3 (neutral, white wire) and P8-4 (door, tan wire).With the door properly closed, the ohmmeter should indicate a closed circuit
(0–2 ohms). If not, replace the door switch assembly.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Dryer, Drum doesn't turn
repairs should be performed by an authorized repair person. check the thermal fuse located on the blower housing. unplug the dryer and locate the thermal fuse and perform a continuity check. more than likely it is open, replace it.
Jun 03, 2017 | Dryers
GEW9250PW0
First turn off the breakers then back on. Check it then , next I would check the wiring in the back to see that all is connected. Next check, the elements. One may be burned out . My guess is the first thing I mentioned.
Feb 22, 2013 | Whirlpool Dryers
I have a whirlpool duet dryer that runs. but will not heat Model GEW9200lw1. Using the tech sheet I found in the cabinet I have performed the heater test and the ohm reading across the red wire at the...
Hi stevewillis1,
Please look at this Service Manual for your machine: LINK
Chapter 5 - Sub page 5 explains that there is an additional resistance test to perform, after the Ohm test.
Please follow the instructions contained within.
Hope this helps
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 01, 2011 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool dryer WGD5600SQ0,will not tumble..door switch activates light and timer..Control panel on/off switch changes states when tested with meter..thermal switch on bulk head measures short , belt ok
Hi
The issue is with the belt that is bad and so the dryer won't turn, to solve the issue you'll have to replace the belt.Hope this helps...please post back for further assistance.
Daniel
Jul 17, 2011 | Whirlpool Dryers
Trouble code f11 or fdl for whirlpool duet front load wash machine.
Hi.
FDL is door lock. This is the first part to be tested, since it can be symptom of a wiring problem.
The door lock is tested by reading impedance on the door latch contacts.
If the door lock is OK, do the following troubleshooting for F11. The problem is usually CCU.
F11 is communication error between CCU (main control unit) and MCU (motor control unit - additional control module connected to motor and to CCU, located in a sealed box inside the washer).
This usually means that either CCU or MCU is defective. In some case the connectors or the wiring harness connecting the two modules is the problem.
The tech sheet says:
F11:Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Solution:
* Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
The wiring harness is tested using a multimeter to ensure that there is continuity between the MCU and CCU connectors. If a single wire is good it will read zero Ohms (closed) from contact to contact.
Motor is tested reading Ohms, it must be read about 6 Ohms on three different pairs of contacts.
Drive system in motor is checked observing if any of the parts are broken.
MCU and CCU are tested reading volts during operation and testing at component level. The testing must be done by a tech. Check CCU to see if there is any sign of failure (eg burnt spots).
Most of the time the problem is CCU. Trick to repair it include testing and eventually reheating the solder joint of the two on-board relays, cleaning connector contacts with circuit cleaner solution. This in case that the problem is CCU.
Disconnect the unit from power for five minutes as first test. This will reset CCU.
Nov 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool Duet washer keeps stopping in the middle of a cycle with the code F11. It doesn't go through the spin cycle. Any suggestions? Thanks!
Hi.
Solution:
* Check MCU
* Check CCU
* Check Motor
Oct 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
74 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
