Tv t1413 key
I had this tevion t1413 tv, while i was going through the menu on the screen, i saw something like key lock which i thought to setup, but i could not complete the process and i switched off. When i turned it on later, it was only asking me for a key lock which i do not even know and i fiddled with different keys but it won't open. could any one just tell me how to disable this this or unlock it. Thanks in anticipation . Divine
  • DontbuyAldi Nov 18, 2007
    I have the same issue. Model is Tevion T1413. On power on screen displays 'Key ---' and appears to expect a 3 digit code. I do not know the code. Is there a way of setting this back to default or some way in?
  • 3,130 Answers
What make and model of TV set?
Posted on Aug 30, 2007
How to set Tevion clock
need to get into the setup menu or unplug the unit and start over..its in the setup menu..
Feb 02, 2014 | Televison & Video
Cannot retune channel 5 on my tevion
You need to find a menu which has initial setup, setup channels or scan for channels in it. Without a manual it's difficult for me to guess where it is. Tevion Technical support is on 0161 975 0458
Oct 20, 2009 | Televison & Video
Tv is on lock mode
Try your "menu" button on your remote. There should be something there under setup for locks and unlocks.
Good luck.
Jul 17, 2009 | Apex Digital Televison & Video
I saw your response to a question about the Toshiba 32A33 TV ...
Definitely, there is some keypad failure. There is a continuous contact anyone of the key. Since key is contiunuosly giving command to the processor Remote function is automatically cutoff. My simle Tips to find out key failure. Good key give "Tick" sound when you press the key softly. The sound is very very low, you have to observe carefully. Otherwise blindly change all the front panel key. Cost is very very low. When the keypad problem is solved, remote will function automatically.
May 19, 2008 | Toshiba 32A33 32" TV
Child lock on and do not know how to disengage
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the function or F button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Apr 09, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Wobbly lines on my Toshiba TW56X81
This sounds like a input problem. The source of the signal may not be well matched to the expected input spec. To test, see if the "SETUP" menu items are clear. If so it is something to do with a cable, connector, or configuration of the source.
Mar 12, 2008 | Toshiba TW56X81 56" Rear Projection...
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Televison & Video Logo
282 people viewed this question
Top Televison & Video Experts
