Question about Canon IR-1022 Copier
What should i use to clean the laser unit? - Canon IR-1022 Copier
    New Friend:
  • 13 Answers
Plz used for clean the laser unit, Soft cotton or Soft cloth and air blower and soft cleaning brush.
Posted on Jul 23, 2013
My cd is not being read on my panasonic cd stereo system sa-ch64m?
I afraid to say the symptom indicates your unit's laser is faulty
First of all I would suggest you to clean the laser lens to see if it solves your problem.
1) Purchase a CD/DVD laser lens cleaner disc and run it through the system 5-6 times.
If you want, you can buy a CD/DVD laser lens cleaner disc by following this link- http://www.amazon.com/Memorex-CD-DVD-Player-Laser-Lens-Cleaner/dp/B00008EM7U
2) If your unit is not under warranty then try this step otherwise it will void your unit's warranty.
If the cleaning disk does not work then remove the cover of the device, you may be able to locate the laser eye clean the laser with a soft clean cue tip or a cotton bud using isopropyl alcohol.Then check with a magnifying glass for any traces of dirt.
If cleaning doesn't helps then you will have to replace the laser diode and replacing the laser diode is very expensive because it requires the entire optical pickup to be replaced and realigned.Therefore I would suggest you to please first of all enquire about the labor,installation charges etc before going for the repair because in some cases the cost of replacing the laser inside the unit will typically exceed the cost of buying a replacement unit.
Oct 30, 2016 | Panasonic Audio Players & Recorders
How do i fix eror code sc221 in a Ricoh 8200dn?
Unless there is a lot of toner around the laser unit that you can clean up and you get lucky, the laser unit is defective. Easy to fix but you have to calibrate it after replacing.
Sep 15, 2014 | Ricoh 8200DN Laser Printer
Clean laser unit
Use compressed air or a photographers soft bristle brush the clean the laser scanner window inside the printer chamber.
Jan 30, 2014 | Canon Office Equipment & Supplies
Pioneer PD-M550
The player have problem with the laser pickup unit.
Try one thing, there is a disc available for cleaning the laser pickup unit (). You will get in any cd shops(instructions will come with it). Buy the cd and the insert it in any one of the tray. It will clean the laser unit if there is any dust in it. After cleaning put a disc and check is the problem remains. If the problem remains the you have to change the laser pick up unit. You can fin a link here which will lead you to the laser pick up unit. You will get the part only against confirm order.
PEA1030
Laser cleaning CD
Ajin
Jul 24, 2012 | Audio Players & Recorders
Richo 2045 paper misfed in C. I HAVE CHANGE THE PHOTOSENCOR AND THE PROBLEM STILL EXIST
i think you were cleaning the machine so when cleaning these type of machines you must be very careful.Okay you must change laser unit and don't blow these machines when cleaning because once the dust goes to laser unit it gives you a code/paper misfed so try to change laser unit
Sep 14, 2011 | Ricoh Aficio 2027 All-In-One Laser Printer
It just shows loading and the dvd dsnt play...pleas guide
hi,
may be ur dvds laser pickup unit have some problem. its Lance may be become dirty. first try to clean it. for that u have to open the dvd player. u can see the laser pickup in side the mechanism of ur dvd player. clean it Lance using an ear dud. don't use pressure on it or do not use any type of solutions. clean only with ear bud. after cleaning insert disk and the check it . if problem remains u have to replace the laser pickup unit.
if u are not aware of opening ur player. bought Lance cleaning disc from market if available.inset it in ot ur dvd player. it will clean laser pickup unit to some extend. remove the disk and then check it.
ok
Dec 17, 2010 | Philips Televison & Video
1035 ricoh aficio printer with error code 322
Yes, the code is caused by toner getting into the laser unit. The laser unit likely only needs to be cleaned out. To do so, turn the machine of with the red rocker switch on left side of the machine. You will need to remove the front cover and the brown cover behind it. The mechanical counter is plugged into the brown cover so be careful not to damage the wires. The laser unit is the black plastic case you will see behind the brown cover. Be sure to remove the necessary screws and connectors. Be extra careful of the ribbon cable, it kinks easily and the contacts are easily damaged. The Laser unit will slide out, and you can remove the screws holding the top cover on. After removal, clean the interior of the case and mirrors. Do not use any liquid to clean it, preferrabley canned air and a lint free cloth. After cleaning, reassemble, turn the machine back on, and test.
Nov 19, 2009 | Ricoh Aficio 1035 Copier
Brother printer mfc 4100 is printing light though the drum and toner cartridge have been replaced. Someone suggested that the laser is dirty..but I do not see how to clean it. I assume it is inside the...
yes mr it is problem your Lser unite laser mirror is dirty .please open your printer cover full body laser unite stand middle position open laser unite black cover and clean mirror tisupaper,laser drum unite six corner replactor mirror clean then solve your problem.If you are not success then toner unite ground point chach or ccd sensor clean
Aug 13, 2009 | Brother MFC 4100 Printer
I have a savin 9935dpe b&W multifunction copier. It states an error code of: "functional problem SC321-00" and to poweroff the machine or call for assistance. I powered off the copier and...
the laser unit can't write, pull out laser unit to clean out (do not open black box ) laser unit located at left down corner of the toner unit. after clean if still not work, change laser unit.
Dec 11, 2008 | Office Equipment & Supplies
Sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
Oct 25, 2008 | Ricoh Aficio 1035 Copier
Canon IR-1022 Copier Logo
32 people viewed this question
old marine
old marine
