Question about Generac Guardian 0C3025 - oil pressure switch
Location on oil pressure sending unit on 2008 hyundai sonata 3.3L
Where on the engine is the oil pressure switch?
Where is the oil pressure sensor located on my 2.4l 2009 Hyundai sonata
you should find it near the front off engine @ crank pulley/oil pump area or near the oil filter housing
Dec 11, 2016 | 2009 Hyundai Sonata
Oil pressure warning light flashes on & off when I start to slow down to a stop????
it sounds like the oil sending unit which is an inexpensive part and simple to replace it should be located between radiator and engine on the side of the oil pan
May 17, 2014 | Hyundai Motor 1998 Sonata
Took my car an 08 Hyundai Sonata for an oil change to the dealer and they told us there was sludge in the engine we have been keeping up with oil changes ,is there a defect with the sonata's engin
There are two main causes for sludge, not changing the oil and filter at regular times, and not running the engine long enough to get it hot.
You might want to get a second opinion from a shop other than the dealer. The dealer may have a sales promotion on engine flushes this month.
Jan 22, 2013 | 2008 Hyundai Sonata
Engine started making ticking noise, checked oil ....very low. added oil, same, added marvel mystery oil, same thing. need an engine job?? 2008 huyandi sonota 4 cyl.
the ticking noise could be the rockers and the clearance may need to be checked and possibly adjusted.you should get the oil pressure checked with a gage to make sure its not an oil pressure problem.and start getting your oil changed on a regular basis as this is the most common problem for engine problems and failure and its the cheapest most cost effective maintenance.
Jun 12, 2011 | 2008 Hyundai Sonata
I need to know where the oli sending unit is and how to replace it?
Fig. 1: Location of the oil pressure switch-3.3L and 3.8L engines
Fig. 2: Location of the oil pressure switch-3.0L engine
Fig.: Oil pressure switch (sending unit) schematic
The low oil pressure warning lamp will illuminate when the ignition switch is turned to the ON position without the engine running. The lamp also illuminates if the engine oil pressure drops below a safe oil pressure level. To test the system, perform the following:
  1. Turn the ignition switch to the ON position.
  2. If the lamp does not light, check for a broken or disconnected wire around the engine and oil pressure sending unit switch.
  3. If the wire at the connector checks out OK, pull the connector loose from the switch and, with a jumper wire, ground the connector to the engine.
  4. With the ignition switch turned to the ON position, check the warning lamp. If the lamp still fails to light, check for a burned out lamp or disconnected socket in the instrument cluster.
REMOVAL & INSTALLATION
On the 2.4L engine, the oil pressure switch is located on the side of the engine block facing the firewall. On the 3.0L engine, the oil pressure switch is located on the oil filter adapter housing, next to the starter motor. On the 3.3L and 3.8L engines, the oil pressure switch is located next to the oil filter.
  1. Locate the oil pressure sending unit on the engine.
  2. Disconnect the negative battery cable.
  3. Disconnect the pressure switch electrical harness.
  4. Using a pressure switch socket, deep-well socket or wrench, loosen and remove the pressure switch from the engine.
To install:
  1. Install the pressure switch into the engine and tighten securely.
  2. Attach the electrical connector to the switch.
  3. Connect the negative battery cable.
  4. Start the engine, allow it to reach operating temperature and check for leaks.
  5. Check for proper oil pressure switch operation.
Hope this helps (remember to rate this answerr).
Dec 22, 2010 | 1999 Plymouth Voyager
2005 hyundai sonata oil light flickers. oil
Yes there is a sensor located on the front of engine on the transmission side(single wire). It cannot be "reset". Possibly loose connection at the sensor,or a faulty sensor, OR... you could be losing oil pressure inside the engine somewhere(lets hope not) these engines are designed to run on very low oil pressure compared to cars of days gone by. The sonata 4 cylinder runs about only 12 psi. The V6 is 7.6 psi or more.
So if it is an oil pressure issue it is extremely important not to run the car before it is fixed or you will need an entire engine.
Jan 24, 2010 | 2005 Hyundai Sonata
Oil pressure sending unit
On all 2.0L and 2.4L engines, the oil pressure sending unit switch is located on the engine block, below the exhaust manifold, on the firewall side. On all 2.5L engines, the oil pressure sending unit switch is located on the engine block, below the front exhaust manifold on the radiator side.
May 24, 2009 | 1996 Plymouth Breeze
Where is the engine number of the 2008 hyundai sonata located?
did you check the front passenger door. the no. on my Hyundai Matrix is located inside the f ron passenger door right on the top right corner. its worth a try
Jan 02, 2009 | 2008 Hyundai Sonata
Generac Guardian 0C3025 -  oil pressure switch Logo
143 people viewed this question
Top Generac Guardian Electrical Supplies Experts
Craig Butler
Craig Butler
epangan29
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
