Question about Building Materials
What's the difference between a roof window and a skylight?
    Scholar:
  • 124 Answers
Roof windows are designed to be accessed easily and can serve as emergency exits if necessary. They can also open up to a 45 degree angle, allowing fresh air to enter a room. Skylights, on the other hand, often cannot be opened at all and are much less easily accessed, meaning they cannot be used as an emergency exit. Hope this helped.
Posted on Jul 23, 2013
I have a 5th wheel trailer and the roof leaks. Can you recommend a sealer that actually works? Everything I've used so far specially for coating trailers just doesn't work.
Silicone glue for around the vent frame and skylights, etc is usually where they leak. Sometimes condensation builds up in the space between your ceiling trim and the actual roof, so insulation and moderating temperatures and venting the roof space becomes important.
Jun 03, 2016 | Cars & Trucks
How to install replacement sunroof motor on a 1999 Pontiac grand prix
Important: This sunroof system is timed from the factory in order to allow the actuator to shut off automatically when the sunroof window reaches a certain position. Use extreme care when removing the actuator from the sunroof module. This may cause the timing to be thrown off. This may damage to the sunroof. Anytime the actuator needs to be removed from the module, ensure that the sunroof window is in the fully closed position.
Remove the sunroof window. Refer to Sunroof Glass Panel Replacement .
Slide the sunshade fully rearward. Move the sunroof window to the vent position. Remove the sunroof screws (two on each side). Remove the sunroof window from the module.
Place the sunroof module in the fully closed position. Remove the headliner. Refer to Headlining Trim Panel Replacement in Interior trim.
Tools Required ?€¢
J 38778 Door Trim Pad and Garnish Clip Remover
J 2772-C Headliner Installer
  1. Remove the sunshades. Refer to Sunshade Replacement .
  2. Remove the overhead console, if equipped. Refer to Roof Console Replacement .
  3. Remove the sunshade retainers. Refer to Sunshade Anchor Replacement .
  4. Remove the power sunroof switch, if equipped. Refer to Sunroof Switch Replacement in Roof.
  5. Remove the sunroof trim lace, if equipped. Refer to Sunroof Seal/Molding Replacement in Roof.
  6. Remove the dome light, if equipped.
  7. Remove the coat hooks. Refer to Coat Hook Replacement .
  8. Remove the assist handles. Assist Strap Replacement
  9. Remove the rail lamp. Refer to Roof Side Rail Lamp Replacement in Lighting.
  10. Remove the windshield side garnish molding. Refer to Windshield Pillar Garnish Molding Replacement .
  11. Remove the upper quarter trim panels. Refer to Rear Quarter Upper Trim Panel Replacement .
  12. Remove the center pillar upper trim panel. Refer to Center Pillar Upper Trim Panel Replacement .
  13. Pull down on the door opening weatherstrip seal on both the front and the rear doors.
  14. Remove the 2 rear retainers (2) using J 38778 Door Trim Pad and Garnish Clip Remover. Disconnect the headliner electric harness at the right side of the rear window shelf. Rotate the right front seatback to a horizontal position. Remove the headliner from the vehicle through the right front door.
Disconnect the electrical connector from the actuator.
Important: Before removing the actuator, ensure that the pins J 41718 are tight and holding the cable.
Thread the J 41718 into the front sunroof window screw hole in order to retain the cable adjustment. Remove the sunroof actuator screws. Remove the sunroof actuator from the module. Did you look for a video on youtube ?
Feb 27, 2015 | 1999 Pontiac Grand Prix
Where do i buy replacement parts for 10'x8' US Leisure shed
where can i buy roof panels for leisure storage shed
10 ft x 8 ft
Nov 24, 2013 | Us Leisure Storage Building. Stronghold 10...
The moonroof on my 98 nissan altima doesn't work
Skylight itself damage, BCM control unit fault, the line problem, sunroof motor does not work and so on all may cause skylight switch failure
auto diagnostic tool
Apr 04, 2013 | Cars & Trucks
My skylight drain is leaking into the car
yes it's either broken or plugged with the skylight retracted look for the drain hose if not look toward the rear of the opening there is probably two drain hoses
Aug 27, 2012 | 2004 Chrysler Pacifica
I dont get gps signal sometimes
I have the same model you have.Sometimes the solution is beyond your control,like tall buildings or heavy tree cover. However what can be in your control is the location of your GPS.Keep it in plain site of the sky above with no obstructions such as roof and covered skylights.
Feb 20, 2010 | Garmin StreetPilot C330 GPS Receiver
How do you replace skylights?
The steps to replace would be :-
  1. Look over the roof area where the current skylight is located. Will it withstand the replacement of the skylight or is the roof in bad shape as well? Assuming all is well with the roof, continue to 2.
  2. Take measurements of the old skylight footing while you are on the roof. View information on the different types of skylights including size specifications. If you do not have to deal with a change in size, this will be a much easier job.
  3. Choose the type and size of skylight you want to buy. There are factory built and site built units. Factory built skylights are the way you want to go. Factory built skylights will seal to your roof better and offer more protection from severe weather. Purchase it from a website or store.
  4. Remove the old skylight by pulling back the roofing area where the current skylight is set. Use a prybar. Remove any mounting brackets present and take off the skylight. This will expose the hole for the new skylight.
  5. Observe existing roof or attic shafts. These are for the new skylight.
  6. Attach new mounting hardware and insert the new skylight. Make certain you read through the manufacturer's instructions, particularly where it pertains to flashing requirements. Installation instructions will vary widely, depending on the style and brand of skylight you selected. Caulk around the entire base of the skylight. Make sure you have not disturbed anything on the roof (such as shingles) that needs your immediate attention.
  7. Insure that there are no problems where the skylight comes inside the house. Take care of any problems with the ceiling view at this time. Check for leaks and loose connections. Assuming all is well, enjoy your new skylight!
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 13, 2009 | Sky Toys
Building Materials Logo
1,027 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
