How to clear computer ram without reboot - Computers & Internet
    Brigadier General:
  • 3,400 Answers
You have to reboot to clear RAM.
RANDOM ACCES MEMORY.
OR YOU MAY HAVE TO LITTLE MEMORY IF THE COMPUTER FREEZES INSTALL MOORE MEMORY.UNINSTALL PROGRAMS YOU DON'T USE
Posted on Jul 23, 2013
How do i clear all forgotten passwords ,including dell security manager authentication password (bios)
with the power off and unplugged disconnect the hard drive for the computer. now reboot and go into the bios and try to clear the password. If it is stall asking for a password with the hard drive disconnected then clear the bios password by the jumper on the motherboard. for the cmos reset. If that does not clear it. remove the button battery and wait 5 minutes and reinsert battery and try again.
you also may have a hdd password if you do then re-post for directions on how to remove hdd passwords. Good Luck.
Nov 01, 2015 | Dell OptiPlex 3020 Desktop Computer -...
Qt 6100
see this instruction and proceed according. God bless you
To partially clear computer RAM memory, close some programs that are currently running. In Windows, right-click on any program in the task bar and choose the "Close" option. That will free up the memory that was used by the program. Even if you close every program running on the task bar, a big chunk of memory is taken up by the operating system. The RAM used by the operating system cannot be cleared without shutting down the system.
  • 2 To clear computer RAM memory totally, you have to shut down the system. In Windows, click on the Start Menu and click the "Shut Down" option. Unix and Linux have similar options. When this process is complete, all RAM will be cleared.
  • Sponsored Links
  • 3
    If you are somewhat impatient, turn off the computer by pressing the power button on the computer. This is slightly quicker than the previous step.
  • 4
    If you are very impatient, unplug the power cord of the computer. If it is a laptop, disconnect the battery as well. The computer's RAM memory will be cleared immediately upon the power source being disconnected. This method of shutting down the computer usually causes corruption or some other problem when the operating system is booted up again.
  • Read more: http://www.ehow.com/how_5054182_clear-computer-ram-memory.html#ixzz2ZPe6cBFn
    Jul 18, 2013 | Computers & Internet
    Cannot access system -- forgot password. Cannot
    Open the computer case. On the motherboard, (looking from the bottom of the motherboard), in the bottom right quadrant, to the right of the CMOS battery, you'll see two jumpers labeled CLR_CMOS and PSWD. You'll want to move the jumper for the PSWD block to pins 2-3 for 5 seconds and then replace the jumper on pins 1-2. This will clear the CMOS password.
    Feb 07, 2010 | Dell Inspiron 530s Desktop Computer
    My pc doesn't boot anymore.
    This code usually refers to a Video card or RAM issue. Try reseating both the video card and then RAM to see if it fixes the problem. If not then try removing the video card and rebooting. If the system starts without the beeps then you'll know the video card is bad and you can replace it. If it still beeps then try removing the RAM one stick at a time, rebooting after each removal. When it boots you'll have the bad RAM stick isolated and can replace. Hope this helps.
    Oct 11, 2009 | ASUS P4P800-VM Motherboard
    Keeps freezing, but works in safe mode, increase RAM?
    If you've only got 384mb of RAM then yes an increase would definitely help. You're probably running with close to the bare minimum of RAM. If you're machine (and budget) can handle it, go for 1 Gig at least.
    Apr 16, 2009 | Gateway 400SD4 Notebook
    Chassis intruded!!
    Clear RTC RAM (CLRTC)
    This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
    1. Turn OFF the computer and unplug the power cord.
    2. Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
    3. Plug the power cord and turn ON the computer.
    4. Hold down the <Del> key during the boot process and enter BIOS setup to reenter data.
    Except when clearing the RTC RAM, never remove the cap on CLRTC jumper default position. Removing the cap will cause system boot failure!If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After clearing the CMDS, reinstall the battery.
    You do not need to clear the RTC when the system hangs due to overclocking. For system failure due to overclocking, use the CPU Parameter Recall (C.P.R) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values
    Mar 18, 2009 | ASUS P5V800-MX Motherboard
    Memory Upgrade causing reboots
    Have you tried to start the computer back up without the new RAM module in?
    If it doesn't get stuck in that reboot loop, you either have the wrong RAM or a faulty RAM module.
    If it does start up but still reboot , then you can start narrowing the issue down to the motherboard.
    You should be able to send it right back and pick up the right one. If you give me the MOBO's make and model I can also tell you what type of RAM you should be running.
    Oct 04, 2008 | Intel Motherboard
    No boot up, display, beep, or HD action
    I am having the same issue. Clearing/reset the bios will get the board to boot up, but when turned off and started again the board will not boot. you will have to clear the bios again. The board seems to be rebooting itself continuously before it evens get to the POST.
    Jun 28, 2008 | EliteGroup P4M800PRO-M Motherboard
    Blue screen
    unistall recently installed hardware or software and try otherwise format the system and reinstall operating system it work ok, till the same problem if you have two rams remove one ram and check
    Mar 26, 2008 | EPoX EP-8KHA+ Motherboard
    Computers & Internet Logo
    21 people viewed this question
    David Payne
    David Payne
