It's not a great solution, but I just stuck a really small cardboard box between the stand and the monitor. I think there's some sort of spring inside that breaks/comes loose. I took off the monitor (for another repair, this time the power supply, blech...) but can't see a way to investigate the mecanism inside the stand. Sorry I can't be more helpful.
Monitor does not turn on automatically when PC is turned on. When it is sleeping and an orange light...
(More)
Monitor does not turn on automatically when PC is turned on. When it is sleeping and an orange light is displayed I turn on the PC and the Monitor begins to turn on, but then just displays a blue screen until I turn it back off and on again manually.
hello i have an syncmaster 740 N LCD of 17 inches i facea problem like some lines come on the screen...
(More)
hello i have an syncmaster 740 N LCD of 17 inches i facea problem like some lines come on the screen color full lines any part of the screen what is the reson behind this
I have an hp L1502 LCD monitor. It remains blank when hooked up to any computer and power source. I...
(More)
I have an hp L1502 LCD monitor. It remains blank when hooked up to any computer and power source. I have tried connecting it to multiple computers and laptops and it doesn't work. I have used other external monitors on this laptop and it works, so I know the problem is with the LCD. As soon as you plug it in the LED begins to flash, it flashes every 5 seconds alternating from amber to amber then turning green/yellow and then back to amber. The light continues to flash like that as long as it is plugged in. I've tried holding down the power button but it seems to have no affect. The LED light continues to flash in the same pattern. Please help!
My monitor is connected to a pc with a Nvidia video card. The monitor just started flashing with...
(More)
My monitor is connected to a pc with a Nvidia video card. The monitor just started flashing with interference randomly. I checked all connections and the video card with no solution. I re-synced the display mode on the video card and that fixed the problem. It has since returned and re-syncing the video card did not fix it this time.
when ever i turn on my monitor, it shows vertical colored lines of green blue, yellow, pink, and red...
(More)
when ever i turn on my monitor, it shows vertical colored lines of green blue, yellow, pink, and red lines all over the screen, i tried checking the connections, i turned it off and on several times, even if it is not connected in the cpu, the colored lines still appear. what should i do? please help. :-s
