My panasonic omnivision tv/vcr combo is stuck in channel/ clock auto set. Every answer I find involves an antenna that I do not have and cannot afford. Is there any way around this?? Please please please help!
5 Suggested Answers
  • 6 Answers
SOURCE: Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Posted on May 01, 2008
SOURCE: Phillips TV/VCR combi 14PV400/07
To solve this problem, cancel the wake up alarm !
Posted on Oct 20, 2008
SOURCE: i have a panasonic omnivision
I have the same tv/vcr combo and according to my Advent unversal remote chart Panasonic code =
one of : 1003, 1054, 1062, 1109, 1170 or 1248
According to my Phillips universal remote chart = 416, 937
Hope this can help you
Posted on Mar 08, 2009
  • 65 Answers
SOURCE: tape stuck in tv/vcr combo
just open it up and get a screw driver and push it out
Posted on Jun 22, 2009
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
When I connect my PVC 1320 to a converted box I
used converted box vedio ouptu to vcr pv-c1320 vedio input used VCR LINE...
Wach tv...
Sep 17, 2009 | Panasonic PV-C1320 13 in. TV/VCR Combo
FROM : ROD MYERS MYCO@SBCGLOBAL.NET I NEED TO RUN THE CABLE INPUT THROUGH THE VCR AND THEN TO THE TV. PROBLEM IS I DON'T KNOW HOW TO PROGRAM TV CHANNELS INTO THE PANASONIC VCR. IT CURRENTLY GOES TO CH 2, 3...
If you have the remote for the unit, with the incoming cable connected to the unit, on the remote, press menu/set up button, once in channel set up, select auto search...it may take a couple minutes for all the channels to be found...once complete, select done/exit, or press the menu/set up button again to exit.
any questions, let me know.
clarkco
Apr 29, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
I lost my remote control for my tv/vhs panasonic omnivision
how do you access the menu without the remote panasonic omnivision tv vcr combo
Mar 31, 2009 | Panasonic PV-C2010 20 in. TV/VCR Combo
My Panasonic Omnivision TV won't change channels...
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Sep 01, 2008 | Televison & Video
Channel/clock auto set
Press both eject buton and rewind button
Jan 22, 2008 | Panasonic PV-C2061 20 in. TV/VCR Combo
Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
May 24, 2007 | Quasar VV-2001 20 in. Combo
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
