Question about Water Heaters
Solar heater and geyser
How can i remove limescale from my solar collector and geyser with out damage it
    Habit-Forming:
    New Friend:
  • 73 Answers
If you have any problem with your geyser it is better to contact with Geyser Repairs Services in Hyderabad Dialfix
Posted on Jan 06, 2016
  • Water Heaters Master
  • 5,245 Answers
Use pump to run white vinegar through pipes.
Similar to illustration showing how to run vinegar through tankless.
http://waterheatertimer.org/images/Tankless-service-valves.jpg
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
Install service valves for ez connection of pump, and then you can do the job periodically with less work.
Posted on Jul 23, 2013
Which is the best Repair center for geyser?
Dial fix is the best service center for geyser.Also called Water Heater, Geyser is a household appliance consisting of a gas or electric heating unit under a tank in which water is heated and stored.
Feb 03, 2016 | Water Heaters
Instruction to repair leaking geyser panel on 150litter kwikot geyser
It sounds like the tank is leaking. Without the information as to where the leak is the only answer I can suggest is to replace it.
Nov 28, 2014 | Water Heaters
Junkers gas geysers
What is a, "geysers pilot"?
Jul 14, 2014 | Water Heaters
Leaking relief valve on solar panel
I had to replace mine a few years ago. Just look on line. Search for pressure relief valve, or add solar. You will get a lot of responses. Comparison shop and buy. On line auctions work well also.
Mar 07, 2014 | Caleffi Solar Collectors
Had burst pipe, used geyser water to bath kid. Water supply now restored but geyser switch in box keeps on tripping... Help!
Use hair dryer and see if you can dry out parts.
Often, when electronics get wet, they cannot be repaired... like dropping cell phone in bucket of water.
Gene
h
Aug 28, 2013 | Mountain Plumbing Water Heaters
What is an anode in a geyser
The anode rod is part of water heater, not part of geyser:
Here are anode rod resources:
http://waterheatertimer.org/Replace-anode-rod.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
The geyser is compressor that attaches to top of water heater, and converts ambient room temperature into heat to heat water using the refrigeration cycle in reverse
Add a comment and fixya might notify me so i can more informeation if needed
Jul 08, 2013 | Water Heaters
How to design and calculate the solar heat panel for hot water system for the concentrated 100 nos. staff toilets and changing rooms of commercial building in Beijing. What is the basic and ancillary...
Usually toilets do not require hot water.
Is the plumbing divided into hot and cold water pipes?
If toilets are hooked to hot water, how many flushes and how many gallons per flush per day.
What is the expected consumption per each worker?
What is the latitude from equator, and expected solar input. Further north, and hazy atmosphere reduce input. Beijing has smog I believe.
How often is the solar panel going to cleaned of smog and dirt for maximum collection?
If the area has hard water, then the entire system is prone to sediment build-up and failure unless water is artificially softened.
Solar water heater temperatures can exceed 180 degrees at times. This temperature will damage storage tank that is not made for that temperature.
Most solar water heater systems have pressure regulating valve and expansion tank to accommodate occasional high temperature and pressure.
A good fellow to contact might be at following website:
http://www.builditsolar.com/Projects/WaterHeating/water_heating.htm
Solar collectors are usually connected to a circulating pump, and then the heated water is stored in a tank.
The pump circulates water continually from solar collectors through a storage tank.
This type of system would use ordinary tank-type water heater for storage.
Most of these systems also utilize a back-up heating element inside the tank.
More complicated systems circulate special liquid through spiral tubes inside the water heater.
This type of heater would be an indirect water heater.
Indirect heaters are used for solar collectors, and used with boilers, or any outside heat source.
http://www.bockwaterheaters.com/Products/products_coil_tank_water_heaters.html
http://www.hotwater.com/products/residential/cirrex_solar.html
http://waterheatertimer.org/images/solar-water-heaters-on-roof_lbiRv_5784111-500x282.jpg
Oct 05, 2011 | Water Heaters
I pipe (sump pump connection) near the hot water heater was leaking and the botton portion of the 'hot water heater' got wet, now the 'hot water heater' will not turn on. Should i assume the 'heater' is...
1) Electric heater, do not touch electric heater that is wet or has been wet unless power is 100% off.
2) Gas heater: Same applies to gas heater if controls are electronic, or if electric is grounded to hot water pipe.
3) Manufactures suggest replacing water heater that has been flooded.
Warranty is voided.
Set next heater higher.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
4) Electric: You can replace thermostats and elements, but if insulation is wet, the unit could short and be continual electrocution danger >>> and you can't operate electric heater with covers removed because cool air will keep thermostats from reading correct temperature.
5) Gas: You can clean out combustion chamber and replace gas valve and burner assembly, but new heater from local hardware or box store will save time and possibly money.
6) Use old heater as tempering tank if incoming water is cold:
http://waterheatertimer.org/Tempering-tank.html
Or use old tank as solar collector:
http://waterheatertimer.org/How-to-make-a-solar-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 25, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water Heaters Logo
123 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
