Question about Gestetner DSm730 Black and White Copier
Cover open when you switch on it shows cover open while all covers are closed
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 72 Answers
It should be indicating which cover.
Posted on Nov 12, 2013
In my OKI c301dn cover open, but it isn't
when cover open in oki c 301 dn then push pull switch is UN link and information show cover open in printers or copiers. just change push pull switch or clean that with ctc the switch you can search on casing were the cover is close and can push that.
Jun 03, 2015 | OKI Office Equipment & Supplies
Cover open sensor is knocked off the switch assembly - Please show and tell me how I can repair it.
Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset it. When the printer turns on, reinsert the cartridges. Make sure the cartridges are properly inserted in the carrier and the lids snap in.
Source: Error: 'Cover open, please close the cover'
May 08, 2011 | Lexmark X6570 InkJet Printer
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
Close front cover
Unlikely the power supply. Sadly I can't think what causes that. I havent workrd on Toshiba for a couple of years now, but there is something else that causes that. Totally unrelated to the power supply or the switch. Have them call Toshiba support .
I am sorry I can't off hand remember the problem. But it is unlikely the power supply.
Jul 23, 2010 | Toshiba E-STUDIO 850 Copier
Brother ax-26 typewriter "cover open"
Small projection under lid has bent or broken. Wedge something in the hole to operate micro-switch. If not effective the maybe micro-switch has moved or is faulty. Short out the wires to micro-switch in that case.
Apr 04, 2010 | Brother Office Equipment & Supplies
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
Error: "Back cover is open. Close back cover."
We had this problem. It turned out there was actually a piece of paper stuck in the printer! It wasn't so easy to see it from the rear.
We removed the paper from the front by taking out the ink cartridge first. Turned the printer back on and everything was fine.
Mar 26, 2009 | Brother MFC 7420 All-In-One Laser Printer
Cover open sign shows all the time
There is an interlock switch or sensor on all the covers. You need to open the cover and look for an opening in the cover it closes against. In those openings there are normally switches that a tab turns on to let the machine know the cover is closed.
The switch may have become dislodged, or more likely, the tab on the cover that hits the switch to actuate it has broken off and is not hitting the switch giving you that message.
Sep 28, 2008 | Lexmark Office Equipment & Supplies
Cover open message
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Jul 20, 2008 | Lexmark X3480 All-In-One Printer
Close top cover
Start by trying this.
Open the cover and look around for openings in the where the cover closes. In those openings there are interlock switches. 1 of 2 things have happened.
1, The switch may have become dislodged.
2. Look on the cover you have opened for actuators, ( pieces of plastic sticking out) that would go into those holes to turn the switch on when closed. Those often break off.
One of those 2 items is your problem, The switch is just not being actuated properly.
Make sure nothing is binding the cover also.
Dec 31, 2007 | HP LaserJet 2420 Printer
Gestetner DSm730 Black and White Copier Logo
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
