Question about Fisher and Paykel GWL11 Top Load Washer
Gw611 not spinning out
  • Fisher and P... Expert
  • 554 Answers
It is stuck on the first rinse cycle and no spin.
Do you get an error code 56.
Error code 56 is mostly common problem with these the motor controllers, SD11 & SD12 brown boards, 3 x 332k resistors near the small transformer go low & need replacing with a 1 meg Ohm resistor will fix the problem. get a qualified technician to replace these parts.
Posted on Dec 13, 2013
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel model no GW611 washes but won't spin nor lid locks
Sounds like the lid lock has gone bad. Check the wire connections to it and if you should need to order the lock, here is their website.
Nov 05, 2012 | Fisher Paykel EcoSmart GWL15
I have lost my instruction manual. It is Fisher & Paykel model GW611 I want to know how to turn off favorites and reprogram it in again
From what I can tell, GW611 is an Ecosmart:
http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/420653_US_Ecosmart_UC.pdf
There are a few different Ecosmart manuals on the Fisher & Paykel website, so you might be able to find one that matches the button shapes you have. They all seem to have the same Favorite instructions:
To set your Favorite Cycle
1. Press the POWER Button.
2. Press the FAVORITE cycle button. Hold down for 4 seconds until you hear two quick beeps and the Favorite light flashes.
3. Select your favorite cycle (eg Regular or Delicate).
4. Select the wash options (eg soak, time saver). Use Advance if you want part of a cycle (eg spin only).
5. Press FAVORITE again to store your favorite cycle.
Note: Your Ecosmart will remember your favorite cycle, or any other cycle that has been customized, even when unplugged from the wall. It is not possible to program a delayed start into the Favorite cycle.
http://www.fisherpaykel.com/customercare/userguide/index.cfm
Jul 16, 2011 | Fisher and Paykel Washing Machines
Our GW611 has problems draining. Washes OK, but when it moves to the first rinse where it is spinning and taking on water at the same time it is not draining fast enough and goes out of balance. It...
Hi - it would seem to me as if the pump is ether overheating or you have a restriction with the drain hose or a combination of both, you need to remove the pump to check it out.
The pump units on F & P washers will pulsate thru out the spin cycles, if H2O left in the bowl then theres a problem with the drainage somewhere.
If theres no blockages found then the pump will need to be replaced...
KK
Jun 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washing machine stopped during spin cycle. now when i turn it on it beeps and has 3 lights on, 2 wash lights and the spin light. model number is GW611 excellence. fisher & paykel top loader
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Jul 27, 2010 | Fisher and Paykel Washing Machines
Fisher & Paykel GW611 Not filling with water
Hi just read your posting.Did you remove any wires to the control module which is located under the top panel when you replaced the bearings.Now did you put the cold inlet hose to the water valve marked with the letter C and the hot to H ?These letters are next to the valves.Have you got the Efficiency option button?Can you select a manual water level instead of just an auto fill?Have you tried to put the machine throe a spin cycle?Do you hear any water coming into the machine at all?Please with additional information to these questions and I am sure we can rectify this problem for you.
Jun 28, 2010 | Fisher and Paykel Fisher & Paykel Washer
It is a GW611 excellence model.It will not go past rinse cycle on
I spoke to a person yesterday that has a next door neighbour that does washing machine repairs and he is going to look at it so i can let you know what the outcome is if you want to know.Thanks Peter.
Dec 12, 2009 | Fisher and Paykel Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
193 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
