Question about Acer Aspire 5742 Notebook
Power goes on and off continuesly
My acer aspire 5742 turns on and off continuously without boot-up, the only way to stop it is to remove the battery.. I've tried to remove the hard disk and switch it on again, yet it worked, I've gone to bios settings to configure ... but of course, i can't use it without my hard disk. I plug my laptop's hdd to my desktop pc to check for available files from it, but yet same thing happened. any of my devices as long as my laptop's hdd is in there never boot up... do you think my hard disk is now defective? how will i retrieve my file if based on that situation? thanks in advance.
  • 3 Answers
Yeah, i think your HDD might be lifespan is nearing it end.
if you want to back up your data inside that HDD, assuming you gonna buy a new HDD soon, just give your current HDD to the seller and they will gladly extract whatever they can from it to your new HDD.
Posted on Jul 23, 2013
Teckies
  • 226 Answers
SOURCE: My Acer Aspire 5004WLMi Crashed and will not boot with Acer recovery disks
turn on your computer when it stars to boot up simultaniously press F8 button run for safe mode then try to launch system restore.
Posted on Jan 21, 2008
  • 38 Answers
SOURCE: acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Posted on Jan 31, 2009
  • 243 Answers
SOURCE: Acer Aspire 3050 will not boot - LEDs flashing 8 times
My Gateway did that it was due to the power adaptor being loose on the motherboard. Push the cord in and rotate it and continuously push the power button if it starts that is your problrm. You can temporarily fix it with tape once you discover where the cord wants to be or you can use a clamp.
Posted on Aug 26, 2009
SOURCE: Can't get Acer Aspire One on my house wireless net to share files
i have the same problem except i cannot connect/browse the internet, however the netbook does detect wireless connections it just fails to connect to them. it previously used to connect to the internet at my friends boarding school and ever since the system admin at the school switched to 'sonar', or however its spelt, it hasnt worked since... ( and yes i have changed the proxy settings etc back to normal).
Posted on Dec 02, 2009
  • 228 Answers
SOURCE: My Acer Aspire 5535 will
I don't think that you can still update the BIOS of a dead motherboard. But in your case, you can still try these steps if you haven't tried them yet, one might work for you.
- Take battery and ac adapter out then press the power button for atleast 15 seconds. Try to power on the laptop using the ac adapter.
- Reinsert the memory module/s (RAM) of the laptop. In some cases, the unit will not POST (power-on self test) if one of the memory modules installed in the unit is incompatible or defective. However, loose connection may also cause the issue. I suggest to swap memory modules on the slots (if you have 2 memory slots) or test them by turning on the unit with only one memory inserted. Using a good known memory module is also effective.
- If you have an external monitor, try to plug it to the unit and see if you can get an external display. This step will further isolate if you have a motherboard or LCD issue.
- Replace the motherboard or video card if you get nothing from the external monitor.
- Replace or check connections of the LCD cable, LCD inverter or LCD backlight if you get an external display. Note that these last 2 steps require technical expertise; however, if the laptop is still under warranty, then call your hardware manufacturer.
Hope this helps.
Posted on May 30, 2011
Testimonial: "Thank you for the quick reply. I will give this advice a go."
I have Acer Aspire 5742-6475 will not boot up at all. The battery light was on when plug in the outlet but battery light go-off right after I push the computer power button. What's wrong with this co
Could be a bad charger. Could also be the laptop itself, I had something very similar happen to one of my laptops. It's a paper weight now, totally dead.
Dec 31, 2014 | Acer Computers & Internet
Aspire 5742 turns on and off contiously
After you remove the hard disk, did you try to boot the machine with a bootable flash drive or CD/DVD? Booting from a Live Linux disc you create on a different machine (free for download and use) or something like that will determine if the rest of the machine has any issues or not. If it will boot like that, then you may have a faulty hard disk, and need to replace it. I hope you have been backing up your data if this is the case.
Jul 23, 2013 | Acer Aspire 5742 Notebook
My acer aspire 5742 problem
press it on without the battery if this does not solve then there is some fault in the motherboard of the laptop better take it to the technician
Feb 01, 2013 | Acer Aspire 5742 Notebook
ACER APSPIRE 5742 TAKE ABOUT 10 TIMES TO BOOT UP.
If there is extreme heat inside the laptop, this happens. Clean the fan and put new thermal pste/thermal pad to processor and chipsets. Also check for power button problem or any stuck keys in the keypad.
Hope this helps
Dec 11, 2012 | Acer Aspire 5742 Notebook
Acer aspire 5742 does't keep power on battery. itis shutdown imediatly.. how can to fix?
If the power adapter runs the laptop, it is likely the rechargeable battery needs to be replaced. Go to www.ebay.com Type: make and model of laptop, refine search for battery.
Jul 04, 2012 | Acer Aspire 5742 Notebook
Acer aspire 5742 pew71 u01 motherboard is dead what can i do
Remove the main battery and power up, no change! the power supply should be checked for correct output voltage, if okay! the DC jack in the laptop is a common source of trouble from no power to intermittent operation, at this point I would recommend having the motherboard evaluated.
Jun 20, 2012 | Acer Aspire 5742 Notebook
Accer aspire 5742 main board can't turn on
try it without battery installed to see if it's same
if not then battery needs to be fully charged or perhaps replaced
Jun 17, 2012 | Acer Aspire Computers & Internet
BIOS setup
hit F2 continuesly when the acer boot logo shows on the screen...thats all.
Dec 12, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5742 Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
