Question about Watches
Nike Max optics EVO 560 801
Left side of nose bridge gone
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
Sep 28, 2014 | Nike Triax WK0006-001 Watch
Hello! I have a WA0022 NIKE watch and i have to replace the watch straps. Can you tell me where i can find them? Can i buy them from your site? please!!!!!
You can get one by going to "http://www.nike.com/timing/". Select
"support" and on the left side of the page is a box headed "find manual
for your model"
Click on the arrow and then select "outdoor" from the list and then scroll down to select your model from the list.
Download instructions.
Feb 11, 2011 | Nike Oregon WA0022-004 Wrist Watch
CAn you help me? I need the user manual for my Nike Watch Torque WC0067
You can get a manual by going to "http://www.nike.com/timing/".
Select
for your model"
Click on the box and select "training" and you will see a list of instructions.
Choose yours and download.
Jan 20, 2011 | Watches
How do I set the time on the Nike merge uplift watch
I assume that you haven't got your manual.
for your model"
Click on the arrow and select "running" and then select your model from
the list.
May 12, 2010 | Nike Merge Uplift Multi Function Watch for...
Instructions for a nike kids watch?
You can get instructions by going to "http://www.nike.com/timing/". Select
for your model"
the list.
May 12, 2010 | Bulova Watch
Need to reset the time on the Nike Wk6000 watch can't seem to get it to change Help! Thank you!
You can get one by going to "http://www.nike.com/timing/". Select "support" and on the left side of the page is a box headed "find manual for your model"
Click on the arrow and select "running" and then select your model from the list.
Download instruictions
Mar 19, 2010 | Nike Triax WK0006-001 Watch
The hex nuts that hold the bracelet on keeps loosening off. where do i get replacement hex nuts?
If you still have those nuts and did not loose them, visit your nearest watch repair shop and ask to tighten them properly. Watchmakers are using special tool, so they can tighten them very tight. If those nuts are already gone, then you have to visit your nearest Nike dealer and ask for help. Nike do not supply parts to private owners.
Rate me, plz.
Jan 13, 2010 | Nike New Torque WC0068 502 watch
How do I set the time on my digital nike presto watch?
KEEP YOUR FINGER ON THE BOTTOM LEFT HAND BUTTON. WHEN IT STARTS BLINKING PRESS IT AGAIN. USE THE OTHER BUTTONS TO CHANGE TIME
Apr 03, 2009 | Nike Presto CEE WT0001-607 Wrist Watch
How do i change the time on this watch?
Try to find it here:
Rate, please.
Mar 29, 2009 | Nike Midsize Triax 50 Regular Watch #R0082...
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
