Question about Canon PIXMA MP780 All-In-One InkJet Printer
Toshiba dp 2570 "dirty copies"
I have a Toshiba dp2570 copier and we are getting one horizontal line in the middle of the page. We also have what looks like a shadow on our copied pages, it is all over except in a few lines at the edge of the paper. I have cleaned the glass, and we put in a new drum. Any ideas
  • Anonymous Mar 18, 2014
    copier ir 2570
  • 20 Answers
Have you cleaned the insides of the printer? If you have then check the fuser assembly . Thats the part that heats up. It probably has ink on it and is transferring it to the paper. If you cannot clean the fuser roller you will have to replace it or get someone who can.
Posted on Aug 29, 2007
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
Horizontal line on output
Clean the small long glass aside the big glass.
Jul 03, 2013 | Sharp Mx-4101n mx-4101n
Panasonic dp 3030 Paper prints on top and bottom of page but blank in the middle. How do I fix? thanks Are there repair manuals that show step by step instructions on line?
this may be a cause of dirty optics, maybe a problem with developer or a fusing problem. the best thing to do would be calling a techinician
Oct 13, 2009 | Panasonic DP-3030 Grayscale Copier
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Dirty Copies and Black Line in Middle
the electrostatic drum probubly whent out if it was a cheap copier get a new one if it was expensive have it serviced or replace the drum yourself
Jan 22, 2009 | Canon PC-940 Black and White Copier
"Maintenance period reached" pops up on the screen
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Toshiba DP2570 Printer
FAULT WITH MY DP2570 PHOTOCOPY MACHINE
This means the corona wire is broken and only be repiared by the service tech
Mar 24, 2008 | Toshiba DP2570 Printer
Change the langauge
COMO PUEDO PONER EN ESPAñOL EL LENGUAJE DE LA DP 2570? Y QUE DEBO HACER PARA MEJORAR EL CONTRASTE EN EL DISPL<Y?
Feb 26, 2008 | Toshiba DP2570 Printer
Black Spots all over my copies
There are lots of things that can cause this. Inspect the fuser assembly & verify that there isn't any teflon missing from the upper roller & that the lower roller is clean. The spots can also be caused by a build up of waste toner in the cleaning assembly, causing excess toner to be dropped on the copies as they pass under it. The cleaning assembly would need to be removed & cleaned to correct this. The spots are not always in the same place - but are they the same pattern? A worn drum assembly can cause spots that are usually a repeating pattern but located in different parts of multiple copies. Dirty corona wires can also cause random spots & rewiring the coronas would solve that.
Jun 11, 2007 | Toshiba DP2570 Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
102 people viewed this question
Clive
Clive
old marine
old marine
