Sansa fuze 4gb
Hi, I have a problem with sound. I usually use my sansa fuze mp3 in car connecting it with car's sound system. Sound was great, clear. When tune up, music was loud and nice, but once I noticed that eventough I tune up sound it was very low, quality was good but very low pitch. I assume that updating firmware software caused that problem. Do you have any idea how to solve this problem? Thank you very much branislav.stanisic@yahoo.com
Transcend ipod service center in kolkata
Posted on Jul 23, 2013
fdlixboy
  • 79 Answers
SOURCE: Computer will not read Sansa Fuze
did you try to connect from your sanza to onboard usb don't use the front of your pc usb maybe wrong setup or wrong connecting the wire . use the usb located at back of your pc , if you connect the sanza to you pc if have words appear ( found hardware)it mean the sanza need the software driver and you unable to detect without driver..
Posted on Jul 05, 2009
  • 5 Answers
SOURCE: My Sansa Fuze 4GB froze. It doesn't turn off or
try holding the power slide/ button type thing in the on position until it turns off, then try turning it back on...
Posted on Nov 22, 2009
  • 102366 Answers
SOURCE: Not enough space for music DB. Please free 90MB
Remove the microSD card and then delete one or more files from the Sansa's internal memory to free up an additional 90MB.
Posted on Feb 18, 2010
  • 107 Answers
SOURCE: my sansa fuze 4gb mp3 player is stuck on a white
Press and hold the Power and the play button (>||) together for 20 seconds. This will cause it to do a system reset
Posted on Mar 02, 2010
Schmead10
  • 650 Answers
SOURCE: i have a sansa fuze 4gb, and it been really nice
Format the in the explorer
Posted on Jul 06, 2010
Unit wont turn on??? was charging unit overnight,now wont turn on tried holding all buttons for 15,30 seconds
It sounds like it's time for a new battery. Here is your battery:
http://cgi.ebay.com/550mAh-Battery-SanDisk-Sansa-Fuze-2GB-4GB-8GB-/200582416758
If replacing the battery doesn't get this player up and running, you will need to contact Sandisk for repair or replacement of your player.
  • Website: http://www.sandisk.com/consumer-products/
  • Address: 601 McCarthy Boulevard, Milpitas, CA. 95035
  • Phone: 1-866-726-3475
  • Email: support@sandisk.com
Jul 04, 2011 | SanDisk Sansa Fuze MP3 Player
My sansa 4gb fuze wont turn on and when it turned on the screen waz white and stopped working pleaze help
It sound like something happened to the screen. It could also be something with the motherboard inside your SanDisk Sansa. If it's still under warranty I would see if you could have it replaced.
Mar 03, 2011 | SanDisk Sansa Fuze MP3 Player
Sansa fuze mp3 4gb radio does not have any sound!!!
Check your headphones with another system, check your ipod with another headphone if the fault is now confirmed you may have a conection fault with the jack usually if another type had been pushed in. If you are electronics savvy then use right tools to slowly open device, use a good soldering low wattage iron with emi protection to solder up the output jack side. and still if no sound comes the audio amp ic. If not you have a damaged ic. Hope you have tried to reset the device. check this out! helpful? Good day
Jul 04, 2010 | SanDisk Sansa Fuze MP3 Player
My Sansa Fuze 4gb wont turn on and isnt being recognized by my computer, iv also tried to soft reset it many times , nothing seems to work.. help plz..
I've had the same problem with my Sansa Fuze 2GB. It's pretty frustrating, but in order to get it to work, I let it sit without touching it or doing anything with it for a few days. For 2-5 days, do not turn on your Sansa Fuze. After the amount of time has passed, try the soft reset again.
Apr 22, 2010 | SanDisk Sansa Fuze MP3 Player
My sansa fuze 4gb mp3 player is stuck on a white screen how do i fix this
Feb 28, 2010 | SanDisk Sansa Fuze MP3 Player
I don't know how to download music on my sansa fuze (4GB)
On your Sansa Fuze, go to the "Settings" menu, then go to "System Settings", then go to "USB Mode", then select "MSC".
Now, connect it to your computer, then double-click "My Computer" on your computer's desktop to run Windows Explorer. You should see your Sansa Fuze show up as "SANSA FUZE". Double click on "SANSA FUZE", and you should see a folder called "MUSIC". Copy your music into that folder. When done, unplug your Fuze and your music will be on it.
Jan 27, 2010 | SanDisk Sansa Clip MP3 Player
My sansa fuza 4gb shut off and it wont chare or come back on
Hi!
I had the same problem w/ my 4 GB Sansa Fuze after 3 wks. When I took it back to Future Shop I discovered a commis who showed me the secret way to debug it . You have to push & hold down the "Home" & the "Down/Submenu/Options" buttons simultanuously to reset it. It worked for me.
Sep 09, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze of 4gb wont charge
Hi
I have sansa clip which i believe behave the same it never says charging it always says connected but that does not mean it is not charging .
leave your sansa connected for a while and then see if the battery meter has changed .
hope it helps
Enjoy
Jul 17, 2009 | SanDisk Sansa Fuze MP3 Player
Can an 8GB microSDHC card be used in my Sansa Fuze 4GB mp3 player
Actually, it sounds as if the card is working. The more you have on the card, the more free internal memory you'll need so it can build its media database. Remove the card, then delete some files from the internal memory to free up space. Then reinsert the card.
Jul 06, 2009 | SanDisk Sansa MP3 Player
Willl not detect
go into settings on the main menu, then go to system settings then go to usb mode and take it off of auto detect and put it on either MSC or MTP
Feb 15, 2009 | SanDisk Sansa Fuze MP3 Player
21 people viewed this question
 Grubhead
Grubhead
