SOURCE: Paper
Hi. The PCR-T470 is only a single roll machine, so if you had them printing at the same time, you would be handing the customer your journal when you gave them their receipt. This machine can be setup either as journal only (in which case you use the black takeup reel that sits inside the printer housing), or receipt mode (in which case you have the paper coming out of the front of the printer cover). The best thing about single roll machines is that when you have them in recipt mode (recommended), you can print the journal out of memory whenever you want. to do this, turn the key to X mode and press RC button until you see 'electronic journal', then press CASH to print it. you might be able to reset the journal by doing the procedure in Z mode (the manual isn't clear about this). Give it a try.
Hope this helps. Let me know if you have more trouble.
Mark
SOURCE: how to reprint reciept on casio pcr t2100
easy... press the "RECEIPT" button on the keyboard. Provided it was programmed in PGM3 to allow reprints.
SOURCE: I have problem with my casio pcr-272 register...I
Hi.
I don't have information on this model, but it sounds like it is one of the very low end registers. These machines can not have the printing turned off. They were designed to be journal printers or continuous receipt printers. You need to buy a machine with receipt memory to get this function. (PCR-T series and above)
Mark
SOURCE: Remove Casio PCR-T2000 Tax Table 2
Hi. You are working in the wrong area. You need to tell each department not to add TAX2. Go to the department programming, and there should be a setting that says use tax1, use tax 2 etc. Turn off tax2 for any depts that you don't want it added and it will no longer print or calculate tax 2 for that department.
For anyone looking for a Casio PCR-T2000 manual, see here:
http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
