Logitech 9 pin connector
Volume drops in an out. have to fiddle with connector for music to come on, and music goes off when connector fully plugged in.
3 Suggested Answers
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
SOURCE: logitech x-230 9 pin problem . i need to manualy
worked on this for 3 days but i finaly got it I had to open it an follow coper lines using datasheet, the connector is RS232 the pins are
1 = LED+
2 = IN R
3 = OUT R
4 = OUT L
5 = GND
6 = ON
7 = 5V
8 = GND
9 = IN L
so you have to put a swiths between pin 6 and 7
you should also put a potentiometer GND-IN-(AUDIO SOURCE)
and a led between pin 1 and GND
and that is it!
---POXTRON---
Posted on Aug 04, 2010
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
I don't know how to install my logictech Z523 speakers; they are hooked up but no sound and not installed; computer doesn't recognize them and my fiance threw out the instructions so I don't know how or...
Your "line in" from speakers should be plugged into the green (output) port on the back of your tower or the headphone jack on laptop. You will need to hook the 9 pin connector from the right speaker to the subwoofer. The yellow line from left speaker plugs into port labled "subwoofer" on subwoofer. Plug your power cord from speaker system into an outlet. Turn them on, adjust volume. There is no software for this product.
Mar 24, 2011 | Logitech Audio Players & Recorders
Logitech x-230 9 pin problem . i need to manualy insert wires into pin holes.. So can anyone tell me the color and pin hole nunber to put right wire into
1 = LED+
2 = IN R
3 = OUT R
4 = OUT L
5 = GND
6 = ON
7 = 5V
8 = GND
9 = IN L
and that is it!
---POXTRON---
May 15, 2010 | Logitech X-230 Computer Speakers
The plug that goes into the subwoofer has broken can they be repairedi.e. the 9 pinned one
Is there any way i can modify the multi-pin connevtor on the back of the sub on my logitech 2.1 system.
Mar 02, 2010 | Logitech Z-3 Computer Speakers
Ipod shuffle wont play
If iPod shuffle isn’t playing music
â iPod shuffle might not have any music on it. If you hear the message “Please use
iTunes to sync music,” connect iPod shuffle to your computer to sync music to it.
â Slide the three-way switch off and then on again.
â Make sure the earphone or headphone connector is pushed in all the way.
â Make sure the volume is adjusted properly. A volume limit might be set. See “Setting
a Volume Limit” on page 25.
â iPod shuffle might be paused. Try clicking the Center button on the earphone remote
Feb 07, 2010 | Apple iPod shuffle MP3 Player
I have logitech speakers for my computer. I need a new cable that goes from the bottom of the bass speaker to the two smaller speakers. A couple of the pins are broken on the plug that plugs into the bass...
logitech rarely has replacement parts. and for this model is not for the u.s. distribution so youcan not even call u.s tech support for help. try ebay or craiglist. if the connector is not proprietary you might be able to get a electronic repair shop to repin the connector.
Jul 24, 2009 | Logitech Audio Players & Recorders
Creative Inspire 5300 Volume Control broken!
For those searching the answer "How to replace/repair Creative Inspire 5300 volume control":
Its simple : looking at the back of the suboofer, the pins are as follows from top right, clockwise : LED VDD , Balance pot middle leg, GND, pots + legs, Volume pot middle leg, on switch input. Connect one pots ends to GND and the other ends to pots +, connect a switch on GND and on switch input, anode of led to LED VDD, cathode to GND (there is a 1,8k resistor inside so no external resistor needed)
Dec 19, 2008 | Bose Companion III Computer Speakers
Need wiring and 9pin connector diagram
Pin 8 = Power A
Pin 9 = Power B
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Warrior Compatibility
buy a connection from a "9 pin" to a USB output
Oct 02, 2007 | Logitech WingMan Warrior Joystick
126 people viewed this question
 Grubhead
Grubhead
