Sony muteki speaker cover
How to remove them
    Genius:
  • Audio Player... Master
  • 1,054 Answers
You have to pry them off. there should be notches in the bottom that you can get a screw driver into. You have to be very careful when doing this and take it slow so you don't damage the cabinet where it is glued to the front panel.
Posted on Jul 23, 2013
Sony Muteki 7.2 USB Fail error, no USB plugged in
Sony Muteki with USB Fail message or turning on and off is generally related to a faulty mains input relay. Search for it in the schematic and replace with a stronger part. Sony uses a very weak relay to connect the mains after power button is pressed. It doesn't last too much.
Sep 19, 2013 | Sony MUTEKI HTDDW1600 Theater System
Will the Muteki sub amp work with a different receiver that has no trigger.
My subwoofer recently burnt out because I had it plugged into a different amplifier.. I wouldn't recommend it. Sony has released the sub to suit that system.. Do keep in mind that I did have bass boost on with the sub up full (Which didn't matter when I had it connected to the Sony amplifier..).
Proceed with caution.. I would recommend turning the sub down and using the sub volume control on the amplifiers settings to change the volume.. Just do not run it at a pace where it looks like it is stressing.. When I say stressing I mean, looking like it is going to jump out of the enclosure..
-Dubkingz
Aug 17, 2011 | Sony MUTEKI HTDDW1600 Theater System
What is happening to my sub woofer????? D: So I have the sony muteki HT-DDW1600 and have had for the past year. In that time it has served its purpose for many many house parties. Recently I noticed that...
If a fuse blows it won't self-heal when you cycle power.
Swap the subwoofers between the two subwoofer speaker feeds. Maybe it will stay with the channel or maybe it will follow the speaker and make next steps easier.
Jul 20, 2011 | Sony MUTEKI HTDDW1600 Theater System
Why does my Sony Muteki XROSSFADE LBT-DJ2i system shut itself off when the volume get turned up?
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Feb 28, 2011 | Sony Muteki XROSSFADE LBT-DJ2i Theater...
Protection
sounds like you may have your speakers connected wrong or too many speakers. Check all your speaker wires for a goo tight connection and speaker compatibility with your Home theater system. Hope this will help you
Dec 20, 2008 | Sony MUTEKI HTDDW1600 Theater System
186 people viewed this question
 Grubhead
Grubhead
