Daikin ftkd50jvea I can't get the controller to select heat mode.
Green light flashing On Daikin fvy453cbv1
how many blinks, look up daikin error reset or daikin factory reset to clear the codes and get into secret service test mode.
Jan 03, 2015 | Heating & Cooling
Do not know what symbols mean on thermostat.
A- automatic, heats and cools
snowflake- cooling mode
sun- heating mode
drip- dry mode
Nov 18, 2013 | Daikin BRC2A71 - Simplified Individual...
Fix error code a5
Freeze-up protection. Check that indoor or outdoor heat exchangers are not clogged with dust or dirt. Check filters also. Reset by turning off power to system for 5 minutes and retry. If problem still exists could be a problem with refrigerant levels.
Sep 20, 2013 | Daikin ARC452A9 Replacement wireless...
Non-tech old lady here. I have 5 remotes, one for each bedroom, & recent guests have been meddling with them & I don't have a clue what I should do. I want them on a/c, which symbol is that?
You can find the manual for your systems here. You can either print it out or look at it in the webpage. If you go to page 4, you should see a diagram of your remote control. You are looking for buttons 17 and 20. One has a little temperature picture with an arrow up and an arrow down, that will raise or lower your temperature. Button 20 is on the bottom right of your remote, which will change your mode (fan, AC, Auto, Heat, etc). Press 20 until you see an A on the display, which symbolizes "Auto" mode, then change the desired temperature with 17 until it's at the level you want.
If this isn't the proper manual for your system, could you please find the model number and post back with that? It makes it a little easier to find. The model number should be located on the unit itself somewhere, or possibly on the outside part of it.
Aug 22, 2011 | Cfm Daikin R410a Split System Air...
Hi, I have a Daikin Model FTXS35D with RXS 35D 3VNB outdoor unit. Until this year it was excellent, now does not cool as before. Have cleaned filters etc. Could it be a sensor problem. When I...
Your unit should cool 15 to 20 degrees. 75 return air temp should be below 60 degree supply air temp. If you are not in this range you likely have a refrigerant problem.
Aug 14, 2017 | Cfm Daikin R410a Split System Air...
Rent a house with a daikin brc1c51/61 with no instructions on how to work control panel for cooling/heating
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.For further details, plz:
www.devicemanuals.com/guide/.../Daikin-manuals.html
Dec 30, 2010 | Heating & Cooling
My daikin inverter does not turn on. when i press on on the remote, the flaps open all the way down then close. the green operation light is flashing.
Seek a refrigeration mechanic. With out looking at the unit it is to pin point problem.
More than likely a PC board issue on the indoor or outdoor unit. Does your remote control give you an error code. If possible look at the users manual on how to get the remote to give you the error code.
Nov 26, 2010 | Cfm Daikin R410a Split System Air...
Theres a weird odour coming from my system, it doesnt matter if its on cool or heat, any ideas? Its a daikin ftxs71fvma
THE ONLT PARTS THATS COMMON WITH BOTH HEAT AND COOL IS THE TRANSFORMER AND THE EVAPORATOR FAN MOTOR.
Nov 27, 2009 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
