Question about Boating
Xantrex pathfinder wiring diagram - Boating
92 nissan pathfinder radio
need a diagram of wires. can buy manual of go to local auto zone and they may be able to print you out one at no cost...good luck
Aug 13, 2012 | 1992 Nissan Pathfinder
Where can I get PCB for my xantrex DR Series power inverter. PCB number is 39cx3yM. I'm in Tanzania.
Officially Xantrex has the position of Note: In order to protect our intellectual property, Xantrex does not release schematics, part lists or wiring diagrams to the public. Xantrex does not sell internal parts to the public. If you need an internal part replaced, your inverter will need to be serviced by an Authorized Service Center or at the Xantrex factory.
So your options are to ship it to an authorized Xantrex repair depot, or reapair it based on electrical knowledge in general
If you decide the latter approach, you have to see if there are any IC's or other semiconductors you can identify. If they are true sine wave inverters- the wave form genesis is what counts- you will have to locate the low frequency oscillator, if it will power up and you have an oscilliscope. you can see if the waveform genesis is a square wave originally, triangle wave or a sine wave. essentially move through the traces to see where the signal goes away. your failure point will be close.
If the original waveform is sine wave, applying class A, AB or B audio amplifier principles should allow you to effect repair.
If the original waveform was square wave or triangle wave- the wave form is shaped by an LC network. Depending on what sized Capacitors and inductors are inside of the cabinet will determine where the sinewave form was achieved. If they are physically small, the waveform was shaped off the Pulse Width modulation circuit, audio amplifier principles should apply in the circuit trace and troubleshooting with the scope.
if they are physically large- the waveform is shaped at the output device(s) Usually an IGBT or power darlington..
If you are working with a modified sine wave inverter, the principles and block diagram is similar to a Class D audio amplifier or a crude AM transmitter with none of the pass filters (oversimplification perhaps)
this ought to be either enough of a start or enough of an outline for you to determine how you want to proceed.
Dec 30, 2011 | Electronics - Others
I am trying to fix my xantrex freedom 10 inverter/charger but I need the internal wiring diagram. Is there I way that I can get it?
Unfortunately, to protect their proprietary designs, Xantrex does not provide parts or schematics except to their factory authorized service network. Assuming it is not still under warranty that would be voided by removing the cover, you might be able to see any obvious damage and procure the necessary repair parts from a third party, but that might be a lot of trouble to track down without any guarantee that it would actually fix the problem. If the unit cannot be uninstalled and/or brought to a service center, some reps do make "house calls", albeit for a fee.
Jun 10, 2010 | Xantrex Technology Xantrex 458 10 12...
1995 nissan pathfinder XE 8 speaker wiring COLOR CODES
1995 Nissan Pathfinder Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Blue
Car Radio Dimmer Wire: Red/Yellow
Car Radio Antenna Trigger: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Blue
Right Front Speaker Wire (+): White
Right Front Speaker Wire (-): Black
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Roof Mount
Left Rear Speaker Wire (+): Light Green
Left Rear Speaker Wire (-): Purple
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
Nov 20, 2009 | 1995 Nissan Pathfinder
Wiring diagram for a 1992 nissan pathfinder
try your local library for the wiring diagram and they will even make copies for you
Mar 01, 2009 | 1992 Nissan Pathfinder
Boating Logo
32 people viewed this question
Top Boating Experts
ray gallant
Bill Boyd
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
