Question about Kenmore Refrigerators
106.51102110 I am not hearing compressor kick on. Water leaking. Bought 23 months ago!
The air ride in my 02 seville wont raise the rear.I hear the compressor kick in when the car is started at least i think its the compressor it's coming from the rear Any idea how to fix it ?
Here's an idea to get you started.
Put the back end of the car up on ramps so you can crawl underneath it.
With the front tires blocked securely, have a helper get into the car and roll down the windows so they can hear you talk from under the car.
Have the parking brake set.
Take a bucket or container of soapy water and a brush, and / or a spray bottle of soapy water, and crawl under to car.
Have the helper start the car, and look and listen for leaks.
I have heard the air bags leak on air ride cars after a few years. The soapy water should show a leak when applied to the air bags and the air lines.
Jan 07, 2013 | Cars & Trucks
Water heater leaks on top
Sounds like an improper installation. It shouldn't be leaking after only two months.
Apr 29, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
A/C Refrigerant
With the compressor not running,20 is low,if the pressure is 20 with it not running,then it would drop to nothing if it was running,so yes,it needs freon,the leak is most likely going to be the compressor on this model,this is a ht6 compressor and was a bad design.You will have to replace the compressor and the orifice tube,and the dryer to repair the problem.If you where to refill the ac system it could last a good long time,or could just leak out with in a day or two,depending on how bad the leak is,but it is worth the try and see ,have it charged,the low side pressure,witch you are seeing,on your gauge should read about 40 to 45 psi if there are no restrictions,or problems in the ac system.If this was helpful,please rate,and thank you.
Jun 20, 2010 | 1997 Chevrolet K1500
I have an Amana bottom freezer refrigerator, model no. BX21V1C,it stopped cooling and freezing. The relay was replaced 6 months ago and now it has happened again. You can hear the click and buzz of the...
Good day,
Sounds as if the relay has failed again. ....or when relays start going bad, it could be an issue with the internal part of the compressor.
But the relay approach should be your first step.
Thank you for using FixYa
Jan 26, 2010 | Amana ABB1927DE Bottom Freezer...
Manitowoc SD 0852A ice maker compressor will not kick-in
Here's my thoughts, I hope it helps. I'm going on foggy memory here, so I may not be entirely correct.
I worked on something like this a few years ago. The icemold (plate) is vertical, there is a circulating pump that runs water over the mold, with the water freezing as it passes. The sealed system is a heat-pump scheme, it freezes the mold to form the cubes, and reverses to heat for release. And when it works, it makes ice fast. It runs constantly until the ice hopper is detected to be full. (there should be a bail to detect the ice level) The system will not run in the event that it thinks the hopper is full (bail up) but the pump motor runs continuous to avoid it freezing. There is probably either a false detection of "full" or there may be a leak in the sealed system and the system will therefore not run.
Jun 28, 2009 | Freezers
My ac doesnt work in my 2001 tahoe. i bought freon for it. the compressor is not kicking on when i turn the ac on, but the gage shows in the red when i hook it up to try and put freon in it. i shot a...
the a/c system needs a minimum pressure before the system will run. the system must have a leak so just buying freon may last a day or a few months depending on the size of the leak. also leaking freon into the air is ozone depleating, it should be recovered properly.
the system needs to be recoved of all freon. vacuum to -30psi held checked for leaks. (uv dye or nitrogen and soapy water). leaks fixed. vacuum to evacuate moisture and air. refilled with proper amount of freon (too much or too little make the air not as cold).
Jun 25, 2009 | 2001 Chevrolet Tahoe
AC doesn't blow cold air
Threr are suppose to be two sounds comming from the window unit. One, the fan sound and the compressor sounds, (this compresses the refrigerants aove room temperatures (around 240*) & send it to the back coils and remove it to room temperatures and send it to the front coils which if enough freon, it will cool to at least 40*. Turn the thermostat all the way up or down while its off and see if you hear a clicking noise which tells you the thermostat is working which that what calls for cool. If it started loosing cools little by little, then you have a leak, and leaked all the freon out! If it stopped cooling all of once, then your compressor is not kicking in.
Jun 16, 2008 | Heating & Cooling
Warm refrigerator/freezer
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
27 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
