Question about Dayton Permanent Split Capacitor Motor Fan
Wiring dia for dayton 3m505 elect motor - Dayton Permanent Split Capacitor Motor Fan
4 Suggested Answers
  • 87 Answers
SOURCE: How to wire a 1dgv1 speed control to a 1tdu8
You will wire this just like a single pole light switch, take your power from your panel (black) to one of the pigtails or set screws and then take another black wire leaving the speed controler to your blower motor. Take the common/white wire directly to the blower, polarity sould not matter which leads you connect them to in the blower.
Posted on Oct 09, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: I have a Dayton 36
GRAINGER.COM THEY HAVE A TECH LINE, BUT ON THE MOTOR LABEL IT SHOULD HAVE THE WIRING DIAGRAM .. GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
Posted on May 28, 2010
SOURCE: wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Posted on Oct 21, 2010
Reversing a Dayton motor model # c286c1 motor
electric motor reversal requires the field winding to be reversed
this is best done by an electrical motor repair electrician as not getting it right can burn the motor out
Nov 26, 2017 | Dayton Heating & Cooling
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
Motor with no labels
3 phase motors that burn wire have a short in one of the phase wires that is allowing twice much current pass than is allowed. I would remove it and have a motor shop check it out.
Jul 13, 2013 | Dayton Model 3n726a 1.5 3 Phase 3450 /...
115v electrical hookup for dayton motor 1TMY6
Dayton manufacturing is owned by WW Grainger
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1TMY6&op=search&Ntt=1TMY6&N=0&GlobalSearch=true&sst=subset
Contact Grainger 1-800-323-0600
They will have wiring information for each of their products.
The wiring diagram should appear on side of unit.
This 1.5 Hp motor can be wired for 115 or 230 volts
My AO Smith manual would not be specific to your motor.
With AO Smith 115-230V, there are one set of wiring terminals for incoming wires from breaker box. The other wires connect to terminals.
Copy following illustration link:
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Wire and breaker size:
For 120Volt, use 20 amp breaker and 12 gauge wire up to 25 feet.
Over 25 feet up to 100 feet, use 30 amp breaker and 10 gauge wire.
100-150 feet use 8 gauge wire and 40 amp breaker.
150-200 feet use 6 gauge wire and 50 Amp breaker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 28, 2012 | Dayton Permanent Split Capacitor Motor Fan
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
I have a Dayton 36'' chicken house fan with 115/230 there I found 6 wires, orange &black wire nutted together . white,yellow hooked to electic(White wire from electic). purple hooked to (black...
May 27, 2010 | Dayton Permanent Split Capacitor Motor Fan
Changed out blower motor on elect furnace.the old motor had three wires one fed the compaster.new motor is revirsable has purple wire,red,blue,black.hooked up purple 1st phase,red for high 2nd phase. is...
hmmm . you better check on that before firing it up ... normally the colored wires are for different speeds .. only one speed can be connected at a time .. usually the high speed winding is used for air conditioning and a lower speed winding is selected by a relay for heating .. ... the way the capacitor is hooked up determines which way the motor will turn .. your old motor with just 3 wires was probably a single speed motor .. normally the black wire will be connected permanantly to one phase .. the other phase then goes to the selected speed winding (color of wire) .. one goes to the starting capacitor . the others even if not connected will be hot electrically so need wire nuts to prevent shorts ..
Jan 03, 2010 | Dayton (2C373) Fan
Oct 09, 2009 | Dayton Dryers
Wiring diagram for dayton ac electric motor
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
Dayton Permanent Split Capacitor Motor Fan Logo
139 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
