Question about Sunterra Garden
Sunterra pond pump and filter needing to be cleaned too often
I bought a 4 x 6 x 1 Sunterra pond kit at Aldi's several years ago but just got it installed this spring. The small Sunterra pump and filter that came with the kit initially only needed cleaning once every day or so. Now it clogs up and the water 'bubble' reduces to nothing within an hour of cleaning. Can anything be done? Or do I need to buy a UV sterilizer for my small pond? Or maybe a bigger pump and filter? I don't think it's the pump that's inadequate, but the filter that's in it. Clogs up with algae very quickly.
pondking
  • 21 Answers
SOURCE: I need a replacement O-Ring for my Sunterra 300106
Call the Manufacturer directly
800#: 866-866-4486
Email: mhardesty@sunterrausa.com
Phone: 309-690-2546
FAX#: 309-690-2547
Posted on Mar 03, 2009
SOURCE: Missing a owners manual for a Garden Treasures biological filter
I have the manual, and I can scan it as PDF, but dunno how to send it to you.  I guess this site won't want us to post email. The Canister is very easy to use, just DO NOT remove the metal tension seal ring.  To prep it, you first have to remove the 4+1 top screws; remove the top part (be careful do not pry the clear plastic cover off, that should stay intact); plug the UV in its socket and carefully insert the UV light into the center chamber; reassemble the top with 4+1 screws; attach the two cone-shape nozzles to the "In" and "Out" of the canister, if you use 3/8" tubing for the pump, then no need to cut the nozzles, if you use 1/2" tubing, then cut the 3/8" section off, likewise for the 3/4" tubing, make sure the In and Out should have the same flow to balance the pressure inside the canister; turn the handle to "Work" plug the tube from the pump into "In" and connect the "Out" with the tube return to the pond or water fall; Turn on the water pump and plug in the UV light (use GFCI), wait 30 secs, and you should see the flow from the return tubing. Note:  use a 650+ gph bump at least; DO NOT submerge the canister in the water; put the canister on an even surface; cover the canister against rain and moisture.  My 800-gallon "green" pond clears up in 7-days. Good luck!
M
Posted on May 21, 2009
  • 5 Answers
SOURCE: broken cap on indicator for cleaning pond
call Sunterra LLC (LR Nelson) directly at (309)690-2460 (Ill #) or (800)800-0993 (Cal. #) They will ship you one right away !
Posted on Aug 02, 2009
  • 5 Answers
SOURCE: sunterra 300106 pond biofilter 1000 gallon
You can contact Sunterra LLC directly from their website or you can call (309)690-2460 (Ill #) or (800)800-0993 (Cal #) and they will ship you the needed parts right away. Walmart was carrying Sunterra a few years ago and may still carry ...check with them. I also noticed Target on-line had Sunterra. But as far as replacmeent parts, I would call Sunterra directly. Also www.Amazon.com carries a lot of Sunterra supplies !
  • 10865 Answers
SOURCE: Tetra Pond GreenFree 9W UV Clarifier
Hello. Get a tube of plumbers GOOP. Joe
Posted on May 02, 2010
Sunterra o ring
I would like to know that also
May 29, 2014 | Sunterra 30016 Pond Bio - Filter 1000...
Does anyone know where I can get a replacment impeller for a 2008 model Sunterra 2000 gph pump ? The cover comes off and looks replaceable. I have a warranty replacment 2009 model and the cover of it is...
If you find a replacement 2000 Impeller for your 2008 sunterra pump, let me know! I called the company who promptly told me they don't sell component parts for any of their pumps larger than 1250. They very matter-of-factly told me to go buy a new pump.
plasticmaster@msn.com
Oct 29, 2009 | Sunterra 202000 Pond Pump 2000 Gph, Black
Sunterra 300106 pond biofilter 1000 gallon intakeoutake nozzles have broken. Where in the twin cities can I go to buy new ones?
Jul 11, 2009 | Sunterra 30016 Pond Bio - Filter 1000...
I am looking for replacement filtersfor Sunterra Pump #201250
Check www.amazon.com for lots of sunterra supplies
Also you can contact Sunterra LLC directly from their website or e-mail
Their # is 309-690-2460 (ILL) or 800-800-0993 (Cal.)
Jun 11, 2009 | Sunterra 30016 Pond Bio - Filter 1000...
Pump just stopped working one day. It was working fine the day before. Hums when submerged but does not pump.
It sounds like your filter is plugged, Take the filter cover off and rinse out your filter, it should take care of the problem. I clean my filter out every 2-3 days.
Apr 22, 2009 | Garden
Broken cap on indicator for cleaning pond
Apr 12, 2009 | Sunterra 30016 Pond Bio - Filter 1000...
I need a replacement O-Ring for my Sunterra 300106 pond filter Where can I get one?
800#: 866-866-4486
Phone: 309-690-2546
FAX#: 309-690-2547
Mar 02, 2009 | Sunterra 30016 Pond Bio - Filter 1000...
Pump goes on and off
Does the pump have thermall protection? It sounds like its getting hot and tripping the thermal protection switch in the pump windings.
Oct 06, 2008 | Sunterra 450gph Pond Pump
Garden Logo
Top Sunterra Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Sunterra Garden Expert? Answer questions, earn points and help others
