Question about Monarch 9855 Thermal Printer
Monarch 9855 Ink roll creases and causes scratches on printouts. pls help
  • 113 Answers
You may have to reload your ribbon, check to make sure that the ribbon core is attached correct. These printers have a core that goes on only one way, and may either damage the arm or take quite a bit of careful force to remove the core.
That said, look above the printhead. If you are running a narrow supply, you may with to relieve some printhead pressure by adjusting the screws above the ph. There are 2, and they have two positions. One position is for narrow web and the other is for wide. If adjusting the ribbon roller (one with the grooves) doesn't fix the issue, take a look at the pressure screws I just mentioned. It may take a combination of both to fix the issue, or even more if you have an issue with your core or take-up spool.
Good luck.
Posted on May 23, 2008
  • 31 Answers
Usually there are screws on the arm that hold the ribbon that can be adjusted to tighten up the ribbon as it feeds into the printhead area. (just make sure that it's flat and smooth when feeding into the printhead area)If it looks okay and is still causing problems you might need to adjust the roller that is under the printhead because sometimes it is at an angle to the printhead and the result is the wrinkles that you see. (On some models you can't adjust the platen roller and have to adjust the printhead instead but you get the idea of what is going on.) Good luck.
Posted on Aug 30, 2007
How do you change the printer head
Here is the link to the 9855 operator's manual. Page 101 of 132 shows you how to replace the printhead. It's a pretty simple procedure.
Dec 13, 2010 | Paxar Monarch 9825 Thermal Label Printer
Paxar 9855 203dpi printer hd getting problem between 2lack inches pls give me a salution for solve this problem,
you need to have the printhead replaced.
do print test by pressing both arrow buttons at the same time and the unit will do a print test. look for the line BAD DOTS and if the Value is greater than 000 the printhead needs replacing
Feb 18, 2010 | Monarch Paxar 9855 Printer
Where can I buy Paxar Monarch 9855, 9835, 9800 printer spares from
To buy a Paxar Monarch 9855 you can buy it to the nearest appliance center or any electronic center in your place. If you can not see that in your place you can buy it through online. Visit and inquire it in ebay or amazon website. or
Thanks and good luck!
Dec 23, 2009 | Paxar Monarch 9855 Thermal Printer
Different Crystal output from model 9835 and 9855 Monarchs
Your software wouldn't care whether it's a 9835 or a 9855. It can't even tell the difference. Are your supply settings and communications settings the same for both printers? Any error messages on the display when you print?
Jul 08, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Print alignment problem. Prints across 2 lables. not sensing the black line on back of label roll.
As it turns out, a good cleaning took care of the problem. I suspect the sensor bar was dirty so it could not detect the black line on the back of the labels for alignment.
Thanks anyway!
Mike Sunderland
Jun 02, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Paxar 9855 print error
You have a format problem. Something isn't correct in your mpcl code.
Error 400 - "The character immediately following { is invalid or not an ASCII character."
Jun 01, 2009 | Monarch 9855 Thermal Printer
Left side of roll ticket doesn't print.
You have a bad printhead. Shut off the printer and as it reboots check out the display. It'll probably flash "765 printhead error" as it boots up.
The printhead needs to be replaced.
Mar 11, 2009 | Monarch Paxar? 9855 Label Printer
Memory full in monarch 9855
Memory full issues can happen for several reasons, and if you check to make sure that you're serial communication settings are set the same on the PC and printer, consider reconfiguring your printer's memory to accommodate busy or large batches of labels, and you should see this issue go away... but you may have to virgin reset the printer first.
Virgin resetting should only be done if the printer is out of warranty since the manufacturer can void your warranty if you do this. If your printer is under warranty, you should call their technical support group to find out what your options are 1-800-543-6650.
You may find additional assistance from them even if the printer is out of warranty. If you want to know how to reset the printer, please send me a msg and I can walk you through it.
Sep 19, 2008 | Monarch 9855 Thermal Printer
Unable to print or only prints one page
My brother dcp tells me
unable to print check troubleshooing and maintenance chapters.
I have done this and cleaned the printer, it also tells me ink jets empty, they are all new ones.
Driving me mad any suggestions so I can get my sanity back.
Jun 12, 2008 | Paxar Monarch 9855 Thermal Printer
Monarch 9855 Thermal Printer Logo
215 people viewed this question
Top Monarch Office Equipment & Supplies Experts
David Payne
David Payne
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
