Question about Vehicle Parts & Accessories
Avital 4103 Remote start does not work with either key fob
  • 34 Answers
SOURCE: im about to install a
the one you need to use is the wire that shows a 12volt power in cranking posision
Posted on Jan 09, 2009
ltfrc
  • 227 Answers
SOURCE: engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
Posted on Jan 28, 2009
SOURCE: my avital 4103 does not unlock the passenger door
Its not the avital piece that's the problem, it's your INSTALLER that is/was the problem....haha, got somethin wired wrong!! It only does what you install it to do! :)
Posted on Dec 22, 2009
  • 171 Answers
SOURCE: AVITAL 4103 REMOTE STARTER STARTS BY ITS SELF
Check the alarm program it shoudl be programing to turns it On every 2 hours, or if you have a temperature sensor should be programed to turns it On when is too cold.
Posted on Jan 05, 2010
SOURCE: Hello. I have an Avital 4103 system and the key
I have a Dodge Caravan 2001 SE. Had the Avital 4103 installed. My question is, before installation i had a Chrysler car alarm in the van. When the remote start was installed they removed the alarm.
The shut down toggle switch was not installed, also the push button valet switch was not installed also. Is this a correct installation, I was told that I did not need the last two items to be installed.
Posted on Jun 01, 2010
I have an avital 4103 in my 2004 silverado. It won't unlock the doors and it starts but immediately quits.
There is a bypass module that communicates with the truck. It's in addition to the 4103 system. It's lost its programming or is disconnected. Sometimes you can unplug the module, turn the key on, plug module back in, turn key off, then on and start. All should be working fine again.
Jan 14, 2014 | 831002/4100 4100 REMOTE START SYSTEM WITH...
I need to know the steps ( opening driver door, turnig the key on n' off etc,etc. ) to activated the alarm 4103
The 4103 is not an alarm! It's a keyless entry and remote starter. So...what are you trying to do.
Feb 13, 2013 | 4103LX Remote Start System with Two...
I had an avital 4103 remote start professionaly installed and now then i go to put the key into the ignition it wont start. I have a 2001 chevy trailblazer. The dash flashes security and i leave my key in...
U are probly opening the door then hitting ur doorlock button then shutting the door. The factory system is being armed whwn u loxk the door. Try shutting the door without loxking it. See if ur factory alarm light came on. If that solves ye issue, u need to some minor rewire on ur alarm.
Sep 05, 2012 | 4103LX Remote Start System with Two...
I lost my remotes for my remote start 4103. I have an unused keyless entry model 2101. Does anyone know if the remotes are interchangeable so that I can have the new ones programmed to operate my remote...
It is not likely that they could be used interchangably. The reason is the narrow radio spectrum that is used and the desire for such companies to produce proprietary pieces.
It is is possible if you were to get a Fob for a 4103 off Ebay for example, they could be resynched. But the remote start is going to have a different signal than the remote door lock. just so they can be operated independent of each other. So it is not likely the 2101 would do more than sync to the door locks.
Feb 18, 2012 | Remote Start with Two 4Button Remotes ...
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Hello. I have an Avital 4103 system and the key light on the dash does not go out after starting the car, inserting the ignition key and turning. I can drive the car, but the key light keeps flashing and...
Oct 27, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Vehicle Parts & Accessories Logo
12 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
