Question about Coleman Heating & Cooling
Wiring a 6 wire duo therm thermostat to an airxcel 8330*733*
I have an coleman ac with a airxcel 8330*733* 4 wire system that i need to wire to a duo therm thermostat 6 wire system
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
motor1258
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Posted on Aug 14, 2008
  • 127 Answers
SOURCE: a duo therm thermostat (p/n 3105058) was removed
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the “RC” terminal on the thermostat.
c. Connect the “YELLOW” wire from the air conditioner
to the “Y” terminal on the thermostat.
d. Connect the “BLUE” wire from the air conditioner
to the “H” terminal on the thermostat.
e. Connect the “ORANGE” wire from the air conditioner
to the “G” terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
provided.
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
Posted on Jun 29, 2009
  • 534 Answers
SOURCE: We have a duo therm rv analog thermostat. When we
red wire to the r section of the thermostat white (heat) to the w marked on thermostat Green (fan) to the g marked on thermostat yellow (a/c compressor) to the y marked on thermostat. Blue to the c marked on thermostat. Orange to the orange marked on thermostat.
Posted on Oct 30, 2009
tbreeze47
  • 3083 Answers
SOURCE: Still working on our ac inside unit Coleman EB20B
You could have either situation. You could also have a bad thermostat sensor, as it talks about in this blog:
http://hubpages.com/hub/RV-Roof-Air-Conditioner-Maintenance-and-Repairs
This .pdf article about Coleman thermostats might help:
www.rvcomfort.com/pdf_documents/1976376.pdf
Good luck, and hope this helps.
Posted on Sep 22, 2010
We have a Duo-therm by Dometic thermostat that does not shut the ac off. We have to manually shut thermostat off to shut ac off. Any suggestions what we can try or just replace thermostat?
Try plugging the hole in the wall where the wire comes through. Also be sure you are not trying to reach your humidity set point therefore overshooting your cooling setpoint. Referred to "droop" in settings
Jun 01, 2017 | Dometic Heating & Cooling
Need a wiring diagram for duo therm thermostat in a 1994 Kountry Star motorhome
didnt specify model number of stat --can notify domestic they make the duo therm products
dometic com
Aug 31, 2016 | Heating & Cooling
We are replacing a coleman air condiotoner with a duo therm unit and we are not sure if the wiring is the same
some of the wires from duotherm unit not used may be for external sensors not on the coleman unit. have to look at wiring diagrams to know
Aug 20, 2015 | Coleman Heating & Cooling
RV Airconditioner capacitor overload blew up.
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Apr 21, 2013 | Coleman Heating & Cooling
Ac is blowing 3 amp 12 volt fuse in control box it is a duo-therm ac unit in an rv model #57915622
Pinched wire going to thermostat, condenser fan froze, or bad compressor
Mar 02, 2011 | Heating & Cooling
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm AC won't cut off with thermostat
Hi, sounds to me like the thermostat is at fault.You have done nothing wrong to it but cover it up. The t-stat is what controls it, turns it on and off. The only other thing that would keep it on all the time would be that the thermostat wiring could be touching together from the stat up to the unit. You might check that before replacing stat. I have seen this many times.You can start the unit and go up top and disconnect the stat wire and it should stop the unit.Then its either the wire or stat.Let me know what you find,
Sincerely,Shastalaker7
Nov 04, 2009 | Heating & Cooling
Thermostat wiring for second ac unit
Aug 01, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
67 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
