Aiwa nsx v8080 cd problems - Audio Players & Recorders
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
SOURCE: AIWA CD Problems
Sounds like the lasers need a POT (potentiometer) adjustment. Tools you will need are a multimeter with Ohms (preferably digital) either a #1 or #00 and #2 philips screwdriver. You will need access to the bottom of the laser. On the units I've worked on the POT faces the back of the unit. It will look like a philips head screw in a square metal casing. You should not need to completely remove the CD tray assembly but you can if you wish though I recommend removing the tray bezel Look for two legs on the side of the POT casing that go to the laser PCB. Measure the resistance across the two legs for an initial reading. On mine it was exactly 1kOhm. Now take the #1 or #00 philip screwdriver and adjust the screw to lower the resistance. POT screws are typically EXTREMELY sensitive so 1/16 of a turn can make a big difference. Start by lowering it by about 20-25%. So if the initial reading was 1kOhm aim for 750-800Ohms and test. You should use several disks for testing. If your unit is capable of CD-R/RW playback then have those available as they are generally more difficult to read. If you have playback gradually increase the resistance 5-10% until the disk is no longer readable or struggles to read. Now lower the resistance again 5-10% and retest. If all works well reassemble and enjoy. It is necessary NOT to lower the resistance too much as it will shorten the life of the laser and if too low could damage the disks. If you must go lower than 25-30% the laser is not worth salvaging. Typically 10-15% is all that is required. If you need more detail I recommend doing a search for 'xbox POT adjustment' as the procedure is essentially the same for all lasers and some xbox sites have good pictures so you can see what your doing before you dive in. Total repair time per unit will be 1/2 - 1hr, mostly spent in all the testing. Hope this helps. Good luck
Posted on Jan 29, 2009
SOURCE: How to play CD on Aiwa NSX-3500 (part of CX-N3500U) w/o remote control?
I thought that I had the same problem. I then discovered that when I put 3 CD's in it started up on it's own. If you push the demo button you can see how it's supposed to light up the number of tracks in a square on the right of the display. It wasn't doing that until I put in all 3. Then it started up and I was able to use the disc 1, 2 & 3 buttons to change from 1 CD to the next and I used the Up and Down buttons to change songs and the play button above the tape deck is multi-functional. Hope this helps.
Posted on Apr 27, 2009
localwonder
  • 6784 Answers
SOURCE: CD player not tracking right
These are the early signs or optical lens assembly failuer. i would start preparing to replace this assembly. the tracking motor and rail are damaged.
Posted on May 28, 2009
  • 7 Answers
SOURCE: aiwa nsx-999 display and cd changer problems
replace lazer ever 2000 hours the display may have a dry joint on the 18 volt input ps the lazers are all the same in all the nsx moduls
Posted on Mar 23, 2010
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: http://www.retrevo.com/support/Aiwa-NSX-AJ800-manual/id/1076dj383/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Apr 30, 2011 | Aiwa NSX-AJ300 CD Shelf System
Looking to find manual for AIWA NSXu2100
Try the link below:
http://www.bing.com/search?q=Aiwa+NSX-AJ20+manual&go=&form=QBLH&filt=all&qs=n
Jan 21, 2010 | Aiwa NSX-AJ20 CD Shelf System
Aiwa nsx-999 display and cd changer problems
I had a similar problem with my NSX-999. For CD, u need to clean the laser or buy a new cd-laser pickup KSS-210A.
For dim display, replace capacitor C107 and C108 in the mainboard if u know how or take to a repair shop and ask them to replace those two capacitors. It soled my problem
Dec 06, 2009 | Aiwa Audio Players & Recorders
Aiwa nsx v900
did you check on speaker wires? Red is +Positive, Black is -Negatives....
Jul 12, 2009 | Aiwa NSX-DS55 CD Shelf System
Accidentally my aiwa 3 cd changer fall down and damaged
Same model is not in stock however new models in Aiwa and Sony are very nice in music.
Jan 25, 2009 | Aiwa NSX-DS55 CD Shelf System
The cd plyer on the aiwa nsx 330 does not recognize cd's.
I can guide you to solve problem in Aiwa NSX-330 but please post problem here as you wrote it in subject area and its incomplete there.
Thank you.
Nov 25, 2008 | Audio Players & Recorders
41 people viewed this question
 Grubhead
Grubhead
