Question about Kenmore 13742 / 13744 / 13749 Built-in Dishwasher
Control panel buttons no longer work.
Starting a couple of weeks ago, when I pushed "Normal" wash, no buttons would light, but when I pushed "Start" my usual settings lit. But the other day, nothing would work, and still doesn't. The circuit breaker is on. The door seems to be locked. I turned the circuit breaker off and back on, but that did no good. No button will light when I push it and the unit does not start. Any suggestions?
  • Kenmore Master
  • 3,227 Answers
Hello ...
I tried to look up your model numbers here (usa)...
with no success... (Kenmore 13742 / 13744 / 13749)
I rarely (ever) suggest owners go direct to Sears...
but this would seem to be.. appropriate...
(I my opinion they are rude & pushy to sell parts
(good news ... here... their guaranteed fit/fix)).
Before doing so...
Check your water, drain & power at the appliance.
With the breaker turned of...
open the appliance cord JUNCTION BOX and assure the
wiring devices (usually "wire nuts") are still tight and secure.
Finding nothing... you are at the UNHAPPY JUNCTURE
where you need to use SEARS PARTS DIRECT...
http://searspartsdirect.com/dishwasher
Posted on Aug 01, 2017
  • 100 Answers
SOURCE: He3 Won't start - lock door or start water flow, although dispay works with no error
The door switch is damaged and needs to be replaced.
Posted on Oct 30, 2007
Washer_tech
  • 164 Answers
SOURCE: Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Posted on Nov 01, 2007
SOURCE: dryer will not start.. Here clicking sound when i push start button but nothing happens
Did you clean the lint screen and replace? Also - all lint should be cleaned from back of dryer and the duct...many dryer manufacturer have safety sensors that will not light dryer due to there being too much lint, not enough air flow...(safety feature) ...
Posted on Oct 09, 2008
SOURCE: Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Posted on Oct 13, 2008
SOURCE: Lock light stuck on, dishwasher will not work
We had turned the power off at the breaker but only flicked it on and off, a friend recommended we turn off the power and leave it off for 5 minutes then turn it back on. This solved the entire problem!
Posted on Jul 12, 2009
Electrolux dishwasher not completing wash cycle and all lights flashing on door control panel and the 'wash pump' error light behind the lower kick space panel was flashing.
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
Jan 23, 2014 | Electrolux Dishwashers
I have a whirlpool DU943PWKQU, first about 6 months ago all the push buttons except light wash stopped working. Now this week it started giving me problems starting all together at first I resolved by...
It seems to be the program controller and you will have to get this checked. Remove the power off for some time and reset it back . If the programs are not responding then you will need to check from the power cord to the control panel to see if this is working and can give hte output with the required inputs when the program is selected.
So does the water go in , if not the controller is faulty.
Sep 29, 2010 | Whirlpool Dishwashers
Control board malfunctioning.
You can try tripping the breaker a half dozen times or so, or else leave it unplugged/without power for a couple days. Once it is plugged back in you may have to leave it overnight and then try it, but that almost always revives it. I notice the problem when I don't use the washer/dryer once a week or don't push any buttons during that time to activate it in some way. Problem seems to occur more frequently in the winter when house is cooler.
Feb 15, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Intermittent problem, unable to select normal wash cycle/start
restart curcuit board sequence
push start hold down air dry and start until lights blink and machine starts then it should work normal
most dishwashers have an instruction booklet behind the botton panel that is nearest the floor you wll have to remove the panel it has a couple of screws. the booklet should be there unless installer took it.
If you omly replaced the front panel board then you may have to replace the circuit board inside the door. It works like a mother board in a computer. Good luck
Nov 17, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Feb 27, 2008 | Dishwashers
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Kenmore 13742 / 13744 / 13749 Built-in Dishwasher Logo
63 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
