Question about NexxTech Transparent LCD World Time Clock (631-1463)
Model 6315541 Digital Clock
How to set the time?
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Set the hour on clock on GE electric stove
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
How do i set the clock on my dvd recorder model number dmr ez28
In the menu look for clock settings. Because this one has a digital tuner you may not be able to set the clock. It receives the time information from the digital TV broadcast.
Feb 25, 2014 | Televison & Video
How to set the digital clock pls
Without your model number this is a GENERIC answer that is applicable to MOST microwave ovens.
1. Press Stop//Pause
2. Press Clock
3. Set Time
4. Press Clock
Time is now set and the Microwave is ready for use.
If this does not work.. I need you to respond with your model number to look up your exact steps.
Thanks for choosing FixYa,
Kelly
Sep 13, 2011 | Microwave Ovens
I have a clock that will not get correct time. I have no way yo set it . Model #44100 Equity.
All Equity Insta-Set clocks automatically set the correct time and date when you turn on the power. Occasionally, the automatic time-setting feature malfunctions and you must reset the time yourself. Manually changing the time to the correct time on an Equity Insta-Set clock requires the push of only a few buttons to get the clock back on track:
1. Press and hold the "Alarm Set" button for five to seven seconds, the year will begin to blink when the clock is ready for adjustment.
2. Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock
3. Set the month, day, hour and minute. Press the "Alarm Set" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
4. Press the "Alarm Set" button after setting the date and time to store the information into your clock's memory.
Best regards,
gylacz
Mar 18, 2011 | Audio Players & Recorders
How to set the time on a simplex series c model number 6334-9140 digital clock
For independent operation, the clock is connected to a reliable source of 120 VAC 60HZ (or 230 VAC 50HZ), and time is maintained with a real time clock chip. Switches located on the front of the clock allow for easy and accurate time setting. For system clock applications, synchronization can be accomplished by connection to Simplex BCD digital data for instantaneous time updates. Clocks can also be connected to power line carrier/synchronous timing inputs that provide hourly and 12 hour corrections. Impulse correction from the 6400 Series Master Clock is ideally suited for Time and Attendance System expansions. A capacitor in each clock maintains timekeeping for approximately 12 hours in the event of power failure in the facility. The Celestra 2000 can be corrected with six different clock codes to suit any specific retrofit or new synchronized time system.
Jan 30, 2011 | Office Equipment & Supplies
I have a atomic clock and dont know how to set it
I have a skyscan Atomic clock model no 86730 and can't set it, every time i get it set, it goes back 1 hr, i need to know to set it to daylight savings time
Mar 17, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Want to chnage time on digital clock
Dear Sir!
Beside the digital clock must be 2 switches, one is for hours and the other is for minute, if it is not when the time is 12:00 take out the clock fuse and enter it again the time will be automatic 12:00.
The clock fuse is under stearing wheel.
Hope to hepled you.
Mustafa, Kabul Afghanistan
Apr 26, 2009 | 2003 Toyota Corolla
Bellsouth model 1188 digital ans machine
Press and hold the "clock" button. You will hear a beep and the display will begin flashing a number which represents the day of the week. 1=sun, 2=mon, and so on. Press the left and right arrow buttons to scroll through. After choosing the day, press the "clock" button again to set the hour. It will start with 12 am and go through 11pm. Press "clock" again after setting the hour to set the minute.You will be able to scroll through 0-59 to choose the minute. When finished, press the "clock" button again to exit the time setting feature.
Jan 26, 2009 | BellSouth Digital Answering System 2006C...
NexxTech Transparent LCD World Time Clock (631-1463) Logo
49 people viewed this question
Top NexxTech Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Pieter Vleeshouwers
Pieter Vleeshouwers
Willem.
Willem.
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
