Question about NexxTech Transparent LCD World Time Clock (631-1463)
Model 6315541 Digital Clock - NexxTech Transparent LCD World Time Clock (631-1463)
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
Nov 05, 2017 | Audio Players & Recorders
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Set the hour on clock on GE electric stove
Manual/instructions for Timex model#75324 atomic clock
Here is a link to the user manual: http://www.acurite.com/media/manuals/75324T-instructions.pdf
Mar 09, 2015 | Timex Atomic Digital Wall Clock
How do i set the clock on my dvd recorder model number dmr ez28
In the menu look for clock settings. Because this one has a digital tuner you may not be able to set the clock. It receives the time information from the digital TV broadcast.
Feb 25, 2014 | Televison & Video
Digital panal is out
I had the same problem with another Kenmore model. Sounds too good to be true, but I unplugged it and left it unplugged for one minute, and then plugged it back in. This caused some kind of a reset and everything booted back up normally. You've probably already tried this, but sometimes it's the simple things that get overlooked... good luck!
Nov 15, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Want to chnage time on digital clock
Dear Sir!
Beside the digital clock must be 2 switches, one is for hours and the other is for minute, if it is not when the time is 12:00 take out the clock fuse and enter it again the time will be automatic 12:00.
The clock fuse is under stearing wheel.
Hope to hepled you.
Mustafa, Kabul Afghanistan
Apr 26, 2009 | 2003 Toyota Corolla
Digital atomic clock radio
Hi. There should be a switch on top of the radio that allows you to select the time zone. It is just behind the snooze bar and labeled PST-MST-CST-EST. Try that.
Mar 31, 2008 | SkyScan 34202 Clock Radio
Clock settings
- Please let us know the make and model number so that we can try to find the user manual for you. -
Oct 02, 2007 | Panasonic RC-6299 Clock Radio
NexxTech Transparent LCD World Time Clock (631-1463) Logo
43 people viewed this question
Top NexxTech Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Pieter Vleeshouwers
Pieter Vleeshouwers
Willem.
Willem.
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
