Question about Fantom Vacums FM741 Twister Bagless Upright Vacuum
Need help fixing a fm741b that is making a loud sucking sound out of the back side!?!
Hi! My Dyson DC17 starts fine and then, within a second, gets very loud with an extra sucking noise.
Hi there, it's Jack at Dyson.
Like most Dyson vacuums, DC17 includes a suction relief valve. This allows extra airflow into the vacuum to protect the motor if the machine is used when blocked. If you've already washed the pre-motor filter and checked all the ducts for blockages, it's possible there's an issue with your machine's cyclone pack which has caused it to block.
We'd appreciate the opportunity to help you check for this - please do not continue to use your machine in the meantime as this may cause damage. When you have your DC17 easily to hand, please give the Dyson Customer Helpline a call on 1-866-693-9766 (US), or 1-877-397-6622 (CA).
We'll look forward to speaking with you.
Mar 14, 2015 | Dyson Vacuums
Makes loud sucking sound from the side hole
It probably has a clog or restriction somewhere. The sucking noise you hear is likely the suction release valve. You will need to trace the airflow path from Motor to floor to locate the obstruction.
Mar 10, 2015 | Shark Vacuums
Motor loud
The beeter bar bearings are bad i just changed the beeter bar on a vacuum that fixed the loud noise check for play in the old beeter bar brush
Mar 21, 2014 | Eureka 4700A Maxima Bagless Upright Vacuum
The small round filter near the handle is sucking in air and making a noise
it should be damaged if u cannot close it, and it will work like a wistle if you dont fix it, so it will be loud.
fix handle hole, and problem will disappear
Apr 22, 2013 | Vacuums
My Shark navigator is making a very loud swooshing sound out of side of canister.
I had the same noise coming out of the side of the canister although I would specify it as a sucking noise. The noise is coming out of a hole on the side of the canister. If you block the hole it sounds normal. This lead me to believe that there was no damage. After further research I found that this whole is actually a release when air cannot make it through the top of the canister. Simple resolution. Take the canister out of its holster and clean both the top part and the metal cone inside and your vacuum will work good as new :) ~=MaGiC=~
Feb 04, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
My Dyson turns on and is not sucking. It makes a
I have the dyson dc 27. On the bottom left back side of mine there is a circle, and ball inside of it. I turned it on and pushed the ball and it started working again. Sometimes it doesn't cover the whole and stops sucking air through it.
May 18, 2010 | Dyson DC07i Bagless Upright Vacuum
My upright kenmore progressive vacuum will not suction up when using the sweeper. It will suction things when I use one of the tools. I have put in a new bag and have tried to see if anything is blocking...
I believe on the front top part of the vacuum is a cover. you need to take it off. behind it you will find at least two filters. You will need to replace the hepa filter and the other one should be like a thin black sponge, you can just wash that one.
If its not that then there are two clips on either side of the base of the vacuum. Pull those clips outwards, then lift the top off, you will see the tube that the hose attaches to. Pull the hose off and check for debris in there.
I hope that works for you.
good luck
Aug 07, 2009 | Vacuums
Loud noise when I start the vacuum in carpet position
It's most likely the Belt Slip Protection Dyson uses to prevent the user from having to replace belts. I recently bought a Dyson and love it other than it literally sits there and makes horrible noises 80% of the time. I completely disassembled the vacuum and found that the spring they used for this belt slip protection is WAY too weak. The weak spring seems to let the belt slip protection pop off way too frequently and unnecessarily. I stretched the spring back out and whammy no more horrible clanking. Of course it'll take you a couple of hours, some good tools and some serious ingenuity to get to where the parts are but problem solved. It'll still ratchet when picking up a sock or dog toy or something, but sitting there ratcheting on short dense carpet is unacceptable. Hope this helps!!!
Feb 14, 2009 | Dyson DC14 All floors Bagless Upright...
Loud whistling noise from back of vacuum
On the back side of most kenmore vacuums, there is an air relief diaphragm that, when the motor is sucking but there is no air flow, will pop, causing the sound you heard. check your hose for blockage, check your bag and or filter for blockage,even your attachments/wands can become lodged with debris. Often, after a few, the motor will get hot and the machine will shut down. This is a thermostat on the motor that protects it from overheating. I am quite sure that this will solve your kenmore woes, fine choice in vacuum, kenmore, tried and true. hope to have helped! Have a super, and hopefully sucking(ha ha) Sunday
Jan 03, 2009 | Kenmore 34720 Upright Vacuum
Fantom Vacums FM741 Twister Bagless Upright Vacuum Logo
20 people viewed this question
Top Fantom Vacums Vacuums Experts
Billy Detlefsen
woodzowl307
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
