Condura airconditioner window type
Error code E4
4 Suggested Answers
SOURCE: window type condura aircon noisy
check fan or blower is unbalancedor touch the frame or fan motor bearings or sleeves defective.
Posted on Aug 29, 2009
hvac1960
  • 2133 Answers
SOURCE: E4 code on lcd dont
E-4 means short of gas. Find leak and arrest. And then vacuum, recharge gas.
Posted on Jan 06, 2011
ZJLimited
  • 17970 Answers
SOURCE: E4 error message on an
Isnt any specific description for this barnd; the only thing I have found is this which is from the manufacturers website If unit displays "e4":
1? Check whether the winding resistance and operation current of the compressor are normal.
2?Check whether the high and low pressure is normal when the unit is running.
3?Check (whether the coil pipe sensor is normal) whether the contact of the inserter on the circuit board is well, the coil pipe temperature sensor is fixed, the evaporation of the indoor unit is well, the key is to check the evaporator temperature detected by the coil pipe temperature sensor has reached the cooling or heating temperature.
4?Check whether the surface of the condenser is too dirty, it should be cleaned when it is too dirty.
5?Check whether the capacitance of the outdoor motor and the fan is damaged, it should be replaced when it is damaged.
6?If the above items are normal, the electric control board should be replaced.
Hope helps.
Posted on May 29, 2011
What does it Mean if there's a cf error code in condura Window type aircon?
That code means COOLING failure and could be a variety of problems from something as simple as a dirty filter to a bad compressor. More info would help me narrow it down
Feb 05, 2018 | Heating & Cooling
What is the code for Condura aircon?
My condura aircon is not functioning the condenser what is the problem...when i check the line they have a suply
Apr 16, 2016 | Universal Televison & Video
I have a waves airconditioner. Its not cooling well n after some time show e4 error. How to remove the error? Plz help.
http://acerrorcode.com/tcl-air-conditioner-error-codes.html
This was googled: waves error codes
It showed a page in "images". Stated
"System abnormity" I think. Page was blurry.
Call a tech! Mini splits can be a troubleshooting nightmare! I think its a Fujitsu unit. It would help, and may save you some $$, to call around to find a technician who has worked on mini splits. And maybe find them a 1-800 # that is their tech support # before hand, so if the tech needs it, you have it. E4 is a vague description for a fault. Make sure you have cleaned air filters, cleaned o.d.coil (turn off power at breaker 1st). Changed batteries in remote. Work safe!
Jun 20, 2015 | Heating & Cooling
ERROR CODE E4 ?
Go to utube https://www.youtube.com
and type in your brand of printer / copier and ask after that how to fix error code E4 .
Example : how to fix error code E4 on a HP model 2400
Aug 12, 2014 | Office Equipment & Supplies
Error code e4 unit airconditioner
Not sure about E4 , but 4 blinks or flashes usually means the compressor isn't starting properly. It could be a faulty start capacitor or wiring or faulty indoor PCB (Board)
Oct 18, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
What is E4 error code o. Yonan airconditioner?
My yo nan midwall split aircon is displaying an E8 error code. What is the fault?
Aug 12, 2013 | Heating & Cooling
Error e4 sir air split unit
We have a SirAir Split unit Airconditioner, It's not cooling and shows e4 error.
Feb 27, 2013 | Heating & Cooling
What causes e4 in an airconditioner
Read your instruction manual section troubleshooting for to see the error code.
if you do not have go to www.fitness.manualsonline.com or www. retrevo.com or www. manualsfactory.com
God bless you
May 09, 2012 | Heating & Cooling
What does malfunction code E6 mean in a koppel super inverter airconditioner
WHAT IS THE MEANING OF E4 code in koppel inverter split type
May 01, 2012 | Heating & Cooling
My airconditioner will not turn on using remote control
Check there will be error code: If not check power to indoor is perfect. Error code details as follows
Code E3
Error detail Remote control transmission error(transmitting error)
Inspected unit Remote control.
Code E4
Error detail Remote control transmission error (signalreceiving error)
Inspected unit Indoor.
Dec 10, 2010 | Mitsubishi MSZ-A15NA Split System Air...
Heating & Cooling Logo
292 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
