Question about Shark VX2 Cordless Sweeper, V1945Z
39 replacement battery v1945zn
Need replacement battery for v1945zn
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
I need a replacement battery for my DirtTamer deluxe V2200
Get a SLA4-6 or UB645 model 6V 4.5Ah battery that says its size is: 2.76 x 1.86 x 4.17 inches.
Can't help you with your regional requirement but this is a good battery source:
http://www.apexbattery.com/rhino-sla4-6-battery.html
-Chris
Jul 25, 2012 | FilterStream Dirttamer Deluxe V2200...
Irobot roomba 500
If you're sure the battery contacts are clean and the battery really is charged, then there is faulty circuitry within the Roomba that would have to be repaired or replaced.
Confirm that the battery is inserted with the metal contacts down so they make contact with the spring terminals in the battery compartment.
Visually confirm that the metal contact plates on the battery pack, and the spring terminals in the battery compartment are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
Visually confirm that the metal contact plates on the Roomba, and the spring terminals on the docking station's home plate are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
If you have a volmeter, measure the voltage between the contacts on the battery pack If it isn't something in the neighborhood of 14 volts and is 11 volts or less, the battery isn't fully charged.
Reinstall the battery.
For the moment, please connect the power adapter directly to the Roomba rather than the docking station to eliminate one possible faultly connection.
If the battery wasn't fully charged, or you weren't able to test it, try to charge the Roomba and then retest the battery voltage if you can. If the battery voltage was higher immediately after charging, but didn't get to 14 volts, the charger is good, but battery needs to be replaced. If the battery voltage was unchanged after attempting to charge the Roomba, the charging circuitry may be faulty. If there was no light patterns when you tried to charge it, and it was plugged in to a good outlet, then the power adapter or charging circuitry is definitely bad.
If you have no voltmeter and you cleaned the contacts and tried to charge the Roomba and it works, use the Roomba and then recharge using the docking station and see if it was just dirty contacts or it won't charge through the docking station. If it didn't work, you'll need to figure out if its the battery, the charging circuitry in the Roomba, or the power adapter. If there are no lights when you try to charge the Roomba, then Either the power adapter or the Roomba power circuitry is defective, but without a voltmeter you can't find out which one, and there's no way to know if the battery is good or bad, but you know Roomba wasn't trying to charge it. If there are lights when you try to charge the Roomba, then at least you know the power adapter is good. Unfortunately, without being able to test something there's no way to distinguish between a charger that won't deliver a charge to the battery and a battery that won't accept a charge. If you want to take a guess then a bad battery is more common and less expensive to fix.
Jul 07, 2012 | iRobot Roomba 560 Robotic Vacuum
Dyson dc16 battery not hold full charge, all three lights stay on indicating a full charge.
If you're concerned that your DC16's battery doesn't seem to be working correctly, please get in touch with us directly. One of our experts will be happy to run some troubleshooting over the phone with you to determine whether the battery needs replacement.
You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 25, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Its showing full battery then after 5minutes showing low battery...
You have a nearly-failed battery.
You'll need to replace your battery as soon as possible, or (like everyone does) use your laptop
while plugged into the wall outlet, because modern battery technology is so substandard, and
after 6 months of use, everyone's laptop battery goes marginal - just as yours has.
Sep 19, 2011 | Vacuums
THE BATTERY WONT CHARGE ON MY DIGITAL MP4 PLAYER PLEASE HELP
The battery itself is need to be check for that. If you charge it for long time and still doesn't charge then the battery is defective. Be sure to replace it with the same type and ratings. Another way to test it is by using a digital tester. Set tester to DC range and point test probe to it's positive and negative terminal. If it measure below its indicated voltage it is defective and need to replace.
Thanks for asking
Jul 07, 2011 | Vacuums
My dyson handheld charges fully, but keeps cutting out when using. About 7 seconds is the longest continual usage time
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to replace the battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
May 21, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Batteries are not recharging. Where can I get replacements for Model EL1000 Pronto Vac?
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
Jan 15, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
How to replace battery for PHV1800 type 1 18vdc
If you are handy with a soldering iron, and don't mind spending a few hours building a new battery pack using 1.2 volt "sub c" cells, you can disassemble the PHV1800, and rebuild the pack yourself. I just did it tonight, and the vacuum works like new.
However, I'm not going to do this again. The PHV1800 doesn't use a single battery pack, but 2 packs that have to be assembled with very little room for error. You can purchase a combination battery pack/motor assembly for $75 (US currency, price currect as of 10/2011), unscrew the screws that hold the vacuum together, and replace the battery/motor unit as one.
Nov 29, 2010 | Black & Decker PHV1800 Bagless Handheld...
Is not charging - no red light
Yes, it can be replaced. Can be ordered from Black & Decker. Some people would say it's worth fixing others would not. Don't know cost of battery -- probably under $20.
Apr 29, 2009 | Black & Decker CHV9600 Handheld Vacuum
Shark VX2 Cordless Sweeper, V1945Z Logo
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
