Question about Water Filters & Coolers
Addi water cooler #ADDI508ED
Broken plastic collar on top that holds water bottle
Replacement can be found at Amazon com Addi water cooler. I hope this was useful. cheers
Posted on Jan 12, 2015
3 Suggested Answers
  • 14 Answers
SOURCE: advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Posted on Jul 10, 2008
SOURCE: sunbeam water cooler model # YLR2-5-25H2
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Posted on May 05, 2009
I have a obsolete but modern-ish Whirlpool water cooler. The white plastic ring the 5 gallon water bottle sits on is cracked, and chunks are coming off. Whirlpool doesn't stock parts for old model
The collar is only there to keep the bottle at the correct height in relation to the water in the cooler. The principle is that when the vacuum inside the bottle is not being release by the water clearing the opening no more water will run out. To understand what I mean fill up a bottle ( any old bottle) right to the top. Fill up the sink and with you finger over the top of the bottle place the bottle upside down in the water. Take you finger from the hole and it will glug once maybe twice then no more water will run out until you lift the bottle out of the sink water. To stop more running out simply put the neck of the bottle bac in the sink. It is the same with you water cooler bottle. So all you need to do now is to to cover the foam with a piece of vinyle and it will be fixed.
Mar 08, 2013 | Cars & Trucks
My primer button as broken how to replace it and where to buy the
Lowes Home Improvement store carries them, also lawnmower repair stores have parts departments that have them. Mine cost about seven dollars.
Apr 19, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
In trying to figure out why my new Schwinnn Airdriver 1100 wouldn't pump (the lever problem pbumgardner had), I removed the plastic collar on the nozzle. I can't get it back on because the plastic threads...
That will entirely depend on how much you want to pressurize these things. Surprisingly, glue does not hold a high tensile strength. I would be nervous using anything higher than 20psi. I don't know what pressure the glue will go up to, but if it breaks at higher than 20psi, it starts to become dangerous.
good luck
Oct 30, 2009 | Cycling
Where are the spark plugs in a 1999 Toyota Carolla and how do I replace them?
Procedure:
  • 1. Remove the two 10 mm cap nuts on the top plastic housing over the engine
  • 2. Remove the two fasteners on the back of the housing and remove the plastic cover
  • 3. You will see four plastic blocks with four wire clips on each block. These blocks are individual coils for each spark plug.
  • 4. Use the small flat bladed screwdriver to carefully lift up on the tab that holds the electrical connector onto the block and slide the wire clip off the block.
  • 5. Remove the 10 mm bolt that holds the plastic block onto the engine. Use the needle pliers to firmly grasp the plastic screw and pull straight up to remove it
  • 6. Loosen the 10 mm nut on end of the plastic rail that holds the wiring harness for the blocks so that the round plastic washer on the bottom of the block will not break when you pull off the block
  • 7. Carefully pull the plastic block out of the engine. There is a 4 inch tube attached to the block that extends into the engine to the spark plug. It will take some twisting and pulling but you must be careful not to catch the back part of the round plastic washer that you cannot see, on the bottom of the plastic wiring harness.
  • 8. The spark plug is at the bottom of the 4 inch hole.
  • 9. Use a 5/8 spark plug socket with a rubber collar on the 3/8" extension to remove the spark plug. The rubber collar will hold onto the spark plug as it is removed.
  • 10. The NGK website recommends making sure the spark plugs have the correct gap .044 but the spark plug box says not to adjust the gap because you might damage the needle point iridium tip. The new spark plug has a protective cardboard tube that is removed.
  • 11. Spark plugs can stick inside aluminum heads and break off when you try remove them, leaving only the threads of the plug inside the engine which will necessitate removing the head to remove broken spark plug. Putting antisiez on the threads of the new spark plug will prevent that in future spark plug changes
  • 12. Now comes an interesting choice. You can use the rubber tube over the neck of the spark plug to slowly drop it down the hole and hand tighten it or you can use the spark plug socket with the rubber collar. If you use the spark plug socket, the rubber collar will stick to the plug and you will pull off the extension, leaving the socket in the hole. A pair of long needle nose pliers will reach into the hole and remove the socket, but the rubber collar may remain on the plug and you will have to bend a piece of coat hanger with a short 90 degree tip to reach into the hole and pull out the rubber collar. The rubber collar is there to prevent you from cocking a regular 5/8" deep socket at an angle which will break off the neck of the spark plug, necessitating another 10 dollars and another trip to the auto parts store.
  • 13. After the spark plug is hand tight, give it 1/2 turn more.
  • 14. Replace the square block, being sure that the black silicone gasket on the bottom of the round plastic washer does not get bound up on the engine post where the 10 mm bolt goes. Tighten the bolt
  • 15. replace the electrical clip.
  • 16. Go to the next spark plug and repeat the procedure.
  • 17. After the last spark plug is done, be sure to re-tighten the 10 mm nut on the wiring harness rail
  • 18. Replace the plastic cover over the engine and you are done.
Good luck and hope this helps.
Sep 17, 2009 | 1999 Toyota Corolla
Poor grinding
Hi
Try calling Baratza at 877 701 2021. They should be able to help.
Aug 28, 2009 | Solis Maestro Electric Burr Grinder
The plastic handles that dispense the water are broken
Where can I buy the spigets for a Sunbeam water cooler. I need one for hot and one for cold water. These handles are not strong enough plastic to last the lifetime of the unit. They should be made from metal. If the taps on our kitchen sink was made from plastic you can imagine how long they would last.
May 27, 2009 | Sunbeam Refrigerators
While in spin cycle agitator spins, but tub does not
Hello, it is the drum shaft collar or what the tub rests on. It is on the top of the shaft. You need to remove the shell, the plastic collar that rests on top of the drum, the agitator, then the nut that holds the drum down, and then pull the drum out, and then you will see the collar. I know it is hard to get to so I would call a pro for this job unless you think you can do it. The part is cheep it is the labor that will cost you. Thank you
Dec 01, 2008 | Kenmore 24032\24036 Top Load Washer
Ring collar broken
wheres the soluiion??????????
May 12, 2008 | Rival 2275WP Food Processor
Washer out of balance ALL THE TIME...
Remove front panel and check the springs that hold the bowl down onto the base. One of them may be broken or detached. On the base, the bowl assembly fits into a plastic collar. This collar may be worn, causing the machine to go out of balance. My guess is that the collar is worn or broken. You should be able to see plastic "dust" or pices on the base or the floor under the machine.
Nov 09, 2007 | GE WPGT9360EPL Top Load Washer
Water Filters & Coolers Logo
1,307 people viewed this question
Top Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
