Front Loader washing machine SAMSUNG WF7708N6W1/XSA door locked flashes
Not sure which compartment soap goes in. Samsung front loader J10451W1/XSA
The soap goes in the front left "container". Also, don't forget to use HE liquid detergent. This is a must for front loaders. I hope that this helps.
Jul 15, 2014 | Samsung Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Sampsung wf7708n6w1 door won't open!
Your door switch/lock is broken, you need to unplug the machine and remove the top, you can then reach down (tight space) and using a small screwdriver you can pry around the switch and get the door to open, you need to get a replacement door switch for the machine.
Leaning the machine back can make it easier to access the switch.
Mar 06, 2012 | Samsung Washing Machines
Samsung Model WF7708N6W1 Washing Machine, just beeps and then flashes "door". Will not start wash?? Its always needed to be pushed in a little but now just assumes the door is not closed even...
The indications are that the door lock is not working or physically broken/misaligned. Alternatively there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor probably requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 19, 2011 | Samsung Washing Machines
Door wont lock
door won't lock & shows d5 code what do i need to fix it?
Dec 18, 2009 | Samsung WF203ANW Front Load Washer
I put some washing in my samsung J845 front loader the door will not lock before the washing can be done. my husband brought a new door latch due to the other one been burnt out and he put it back on the...
Just bang the door again until the error goes away. The door is not lined up and won't latch properly. At least that is what ours does. I usually slam the door on my machine.
Sep 29, 2009 | Samsung Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
