Question about Garden
Removing parking brake handle on john deere mower
Trying to remove the parking brake handle on mower
  • 11 Answers
SOURCE: John Deere LT 133. Will not move with mower in gear and clutch/brake released. A smell like hot rubber prior. Mower will engage. Thanks.
It could be that the belt jumped off the pulleys and got caught between a pulley and a belt guide,or the trans-axel seized up ,or brake was stuck while in a high gear,and burned up the belt. most likely the first reason. if it wasn't for the burning rubber smell,I would also look for a broken clutch/brake return spring .The pedal would stay down with a broken spring
Posted on May 24, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I remove the PTO clutch from a John Deere
Locate and disconnect the power supply cord from the clutch. Remove the bolt, washer and retainer from the center of the clutch, It should now slide off the end of the crankshaft provided you have previously removed anything such as body parts or braces that would be in the way. In some instances penetrating oil must be used to help free it up. When you reassemble it, it is a good idea to use a little bit of anti-seize on the engine shaft in case you have to remove it in the future.
Posted on Oct 30, 2009
John deere z225 parking brake hard to engage
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
May 10, 2016 | John Deere Riding Lawn Mower. EZtrak Z225...
John Deere model la145 park brake won't hold. The mower will still roll with the brake engaged.
brake needs to be tightened up , id almost bet that service brake is a bit loose as well , Jd's use a disk shoe on transmission side that has a simple disk brake shoe on it , have a look at it there's a bolt right on side of it to tighten it up , Less is better on these , don't make it drag as it will heat up and wear down even faster
Jun 23, 2015 | John Deere Garden
John Deere L110 riding mower automatic won't start
have you checked the micro switch under the seat
May 31, 2013 | Garden
Brake pedals are stuck down and cant be moved....
Will need the model number for best results, but insure that your parking brake lever is not still engaged. Typically a lever on or below the "dash". You would need to depress the foot brake and at the same time, release the parking brake handle.
Oct 02, 2010 | John Deere Garden
Problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Brake pedal won't release on a John Deere 316 lawn tractor
I have the same problem. I just wiggle the black handle on the parking brake release. It usually allows the pedal to come back up. One of these days I'll see what hanging up in the linkage.
May 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
The parking brake on my John Deere L118 is stuck in the activated position. Therefore the tractor won't roll. How can I disengage the parking brake?
Usually there is a red handle under the steering colunm that locks the pedal down. You will need to depress the brake as you push down on the red handle which should release it.
Oct 11, 2009 | Garden
Hand break on the John Deere LTR 180 is stuck and
To temporarily fix you need to remove brake linkage to trans.If this works you need to get it to the dealer to replace park brake rod.
Mar 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
