Astone ap360t problem with hard drive
When switched on hard drive makes loud whiring noise and the yellow light continues to flash when viewed through tv loud clicking nioses can be heard. when you select menu hdd screen says cannot load hdd.have swiched unit off and on several times to see if hdd will reset but to no avail
  • 193 Answers
SOURCE: external HDD won't start up
putt the actual hdd in master and the 1 ur having problem with in slave mode boot windows go 2 controle panel administartive tools and device manager or manegment somthink like that and in the diagnostik box take the last option frome the second 1.u must see ur seond hdd that u put on slave..format it...after that putt it alone and boot frome windows xp and install ur windows this will work
Posted on Feb 13, 2008
  • 207 Answers
SOURCE: External USB drive making clicking noise - Windows does not recognize it!
it is going to crash soon as the platter seems to broken it is non repairable yes but u can save the data by taking help of any good tech
Posted on May 19, 2008
darkoh69
  • 77 Answers
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Posted on Jun 01, 2009
acsess
  • 40 Answers
SOURCE: Lacie HD power light flashing yellow and orange
Hi. Sometimes, there are compatibility issues on external drives. Most recent computers will read them while others may not. Either the external casing or the cable is causing this.
Posted on Aug 28, 2009
  • 8 Answers
SOURCE: my external hd makes a constant, loud noise
Back up your files and buy a replacement drive the grinding noise is the hard drive experiencing mechanical failure and may stop working soon.
Posted on Oct 08, 2009
Dell Dimension 1100 hard drive activity light on constantly and hard drive making noise, lagging
Try to create an other user and login with that user, then check if the issue still happen.
Jan 03, 2013 | Dell Dimension 1100 PC Desktop
How i can fix red screen on ps3 ?
Well first of all you can try the below steps -
1. turn off your ps3 with switch at back
2.hold power button
3.(do this while holding pwr button) switch back on the ps3
4. if done correctly the ps3 should make a loud fan noise causing the fans to enhance for awhile, that should clean out anything that could overheat the ps3
Sometimes the red light will be flashing because there is a problem with the connection of the hard drive to the rest of the PS3 or the hard drive itself is broken.
You can usually fix this problem by re-setting the drive. To do this, go to the side of your console and take out the hard drive. Then replace it in exactly the same position. If the red light is still flashing when you turn your PS3 on, you might have to get a new hard drive, or even a new PS3. Please post comments for more help or information..........
Good Luck!!
Thanks
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Hard drive started making a loud clicking noise
Clicks from a hard drive are never good news. If the disk is still readable I'd STRONGLY advise an immediate backup, starting from the most important files. Unfortunately USB does not support SMART querying of disks - you'd need to extract the HD from the enclosure and connect it directly to a PC to do that - but the disk sync information might have degraded to the point that the disk needs to recalibrate fully. This is usually followed, as the degradation continues, by the disk becoming unreadable.
A more detailed description (albeit understandably a bit biased) is here:
http://www.datarecovery.com.sg/data_recovery/hard_disk_symptons_clicking_sound.htm
Nov 25, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My external hd makes a constant, loud noise
Oct 08, 2009 | LaCie Computers & Internet
The hard drive is clicking loudly. It has been doin this for quite some time and my concern is that it is about to crash.
Usually the drive that does start to go bad will make a clicking sound or a loud whiring sound espically when it speeds up and slows down, and am fairly sure if you have s.m.a.r.t.s. enabled it will say to backup and replace the hd. if it is not enabled it is in the bios under a tab to enable and disable it. it is called s.m.a.r.t.s. status or hard drive status.(older laptops will most likely not have it) but yes, i would strongly recommend that you see about getting the hd replaced. you could even purchase a used hd from a local computer store or ebay to backup your current hard drive by using norton ghost or any other type of backup program or roxio backup. DARK
Jun 14, 2009 | Toshiba G15-AV501 Qosmio Notebook
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Cooling fan
Yes. It can be replaced. Try to check which fan is making that sound. Do you have a laptop or a PC? On a PC, there are 3 standard fans inside it. one for the CPU, one for the power supply and one for the computer casing fan as well. It depends on which of those fans it's coming from. On a laptop, some laptops' fans actually makes a loud noise which is common but there is a way that it could be lessened but it might slow down your pc and it might overheat it as well. The loud noise on the fans of a laptop actually indicates that it's trying to cool down the system. If it doesn't stop the loud noise, it could indicate a problem switching the fans back to normal and would just continue to spin fast. Try to contact your PC tech for further diagnostics on the laptops fan to indicate if the problem is with the fan or the mainboard as well.
Jan 02, 2008 | Iomega 33089 250 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
