Canon color imagerunner c5185
I see gray and pink shadows on the paper
color_50
  • 22 Answers
SOURCE: Canon Color ImageRunner - Tab Instructions
To be able to print using tab paper from the driver
Since the tab paper can only be fed from Stack Bypass, single reverse tab paper cannot be
used. The tab paper must be single forward.
1. Go to the printer and put some tab paper in Stack Bypass
2. Press Letter on C3200 LCD panel and press Next
3. Select Tab paper and press Done
4. Go to Windows Start menu and choose Settings
5. Open Printers folder
6. Select Canon iR C3200 PS3’s Properties
7. Click on Device Settings tab
8. Click on Form to Tray Assignment button
9. Making sure that Stack Bypass is highlighted and Paper Size is Letter, select
Tab Paper by scrolling down the Paper Type list
Page 2
Hint:
In order to print to Tab paper, it is necessary to select Tab Paper in the Form to Tray
Assignment dialog box before using this option. Otherwise, the option of printing to Tab paper
is not available from the print driver.
10. Click OK to close Form to Tray Assignment
11. Click OK to close Properties window
12. Open Word document called “tabs.doc”
13. Go to File menu and select “Print…”, and change the current printer to Canon
iR C3200 PS3.
14. Click on Properties
15. Click on Paper Source tab.
16. Select Paper Type option
17. Choose Tab Paper from Paper Type list. As soon as you select “Tab Paper”,
Conflict Information dialog will appear. Click on OK.
Page 3
Hint:
In order to change the tab position, click on Tab Position button. Clicking this button opens a
dialog box for specifying the width for shifting the image data to be printed on the tab part of
the paper.
Hint:
The conflict information displayed pertains to the finishing of the document. Tab paper must
be grouped, not collated. Since the default value for finishing is Collate, the driver
automatically adjusted the finishing option to resolve the conflict.
18. Click on OK to close the Properties window.
19. Click on OK to print the tab paper.
20. Go retrieve your output.
Note:
Please note that this procedure for printing on tab paper is not the same for all drivers. CCD
drivers would be similar to this procedure, but depending on the OS Platform, exact buttons
and steps would vary. However, from such drivers as imagePASS-C1 PS and Macintosh drivers
would work completely different from this procedure. Although we will not cover each
procedure step by step, we encourage you to take time to make yourself familiar with the
procedures.
Posted on Mar 15, 2009
SOURCE: Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Posted on Mar 26, 2009
jcarlton214
  • 105 Answers
SOURCE: GRAY STRIPES ON COPIES
clean the glass. it must have streaks
Posted on May 28, 2009
Cogz
  • 1326 Answers
SOURCE: GRAY STRIPES ON COPIES FROM CANON IMAGERUNNER 210S
Have you replaced the drum unit resently? When you had the drum unit out did you see the lines on the drum it self? If so, you need a new drum... If you did not see lines on it the problem may be coming from the fixing film, most of the time if the film is bad you can rub the toner off the page... Good Luck...
Posted on May 31, 2009
PATHAMPAD
  • 25 Answers
SOURCE: Printing double sided color copies.
CHANGE YOUR DUPLEX PAPER SELECTION MOTOR
Posted on Oct 31, 2009
Sir, my canon ir400 prints phots or pink colour paper very dark, the text print is ok, what should i adjust so it prints the photos and colour papers much clearly. plz help me sir. thank u
You can adjust it thru the settings it is like the menu, all is being adjust there including the color, contrast, bright etc.
It really depends on your need so the choice is yours, adjust it the way you want.
Jun 07, 2011 | Canon imageRUNNER 400S Copier
Canon Color imageRUNNER C2550 legal size copying only works with single pages placed on the glass. Auto feeder ends up with image off center
when you making the copies, you MUST adjust the paper guides on adf/dadf. They are gray plastics left and right from original and can be moved to each other. They guide the paper rightly in adf/dadf.
If these doesn't helps, please describe what happens when dadf pulls the paper inside.
Apr 21, 2011 | Canon imageRUNNER C2550 Color Copier
When printing in color on a canon c3220, images have 'ghosts' or shadows
try to check your paper cassette setting and try to use user mode * select " auto adjustment / cleaning to fix the problem.
Jan 24, 2010 | Canon imageRUNNER C3220 Color Copier
Canon IR C-4580 with Fiery controller
No, but the fiery will just speed up your prints etc.. I have the c3380 and c5185, they are stand alone with no fiery. If you are buying this machine for office coping it will be fine. But remember! this is a Buisness Color machine. In my customer base the 80's have done well as long as you run them as an color machine and not the office black and white work hourse. The color prints are great without any help from fiery. Sales people will try to sell you all!!!!
Jan 06, 2010 | Canon ImageRUNNER 1670F Copier
Sep 17, 2009 | Canon imageRUNNER C3200 Copier
May 28, 2009 | Canon imageRUNNER 210S Copier
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
42 people viewed this question
k24674
