Question about Panasonic Lumix DMC-LZ2 Digital Camera
Spot on finished photo
Fuzzy gray spot in center of phot & another is staring to show up slightly off center
  • zickman Aug 30, 2007
    fuzzy gray spot on printed photo @ on the lcd
    lins appears clean
    does not matter what subject matter
    fuzzy spot is centered and is on the print & lcd
    Genius:
  • 2,985 Answers
More deratail please how do you see the 'spot' on the screen or on the print or both, What was the subject matter? Any muck on the lens?
Posted on Aug 29, 2007
  • john ash
    john ash Aug 30, 2007
    From all that this appears to be a failing CCD
    There is nothing for you to do here except contact Panasonic with the detail as in your most recent.
    Failing CCd's are not uncommon and in the past have resulted in the camera being replaced free of charge- So contact Panasonic support.
SOURCE:
Black fuzzy spot in pictures
Have you verified that it is in the picture and not the screen by transferring the photos to your computer?
You way have some dust or lint that got on the lens if the photos have that problem.
Just take an eyeglass cloth and spray wither eyeglass cleaner, or just a little dab of alcohol and then wipe the lens clean.
May 26, 2012 | Canon PowerShot SD1300 IS IXUS 105...
Tip
ER151 fix to open to change batteries
Photo P1120573 push this out.<br />photo 1120586 Then you see two screws. Unscrew them.<br />You see phot 1120570<br />Take the plastic away.<br />Then you see P1120558 <br />Then push with a screwdriver a little bit<br />See photo P1120568<br />Then take the piece away.<br />Photo 1120559<br />Take the little screw away at the end off the ER151.<br /><span>This</span> <span>screw</span> <span>is</span> <span>visible.</span><br /><span></span>Watch out for the little springs Photo 1120561.<br />Take out the two plastic things. photo 1120564.<br />Take out the elektrical PCB. photo 1120565. and cleaning it. with a little<br />steel wool. 1120566.<br /><span>You</span> <span>can</span> <span>also</span> <span>contact</span> <span>points</span> <span>slightly</span> <span>upward.</span> <span>So</span> <span>you</span> <span>better contact</span> <span>on the PCB.</span><br />Clean the little contact's with steel wool.<br /><br />Change the batteries. <span>and</span> <span>put</span> <span>it back</span> <span>together :) :)) :))) </span><br /><img src="kwiekie.jpg" /><img src="kwiekie_0.jpg" /><img src="kwiekie_1.jpg" /><img src="kwiekie_2.jpg" /><img src="kwiekie_3.jpg" /><img src="kwiekie_4.jpg" /><img src="kwiekie_5.jpg" /><img src="kwiekie_6.jpg" /><img src="kwiekie_7.jpg" /><img src="kwiekie_8.jpg" /><img src="kwiekie_9.jpg" /><img src="kwiekie_10.jpg" /><img src="kwiekie_11.jpg" /><img src="kwiekie_12.jpg" /><img src="kwiekie_13.jpg" /><img src="kwiekie_14.jpg" /><img src="kwiekie_15.jpg" />
on Jun 22, 2011 | Panasonic Hair Clipper ER1511
Blue and Pink spot on my Panasonic Projection LCD
Panasonic didn't release a 61" LC13, are you sure that you dont have a PT-61LCX65, 35 or 15. If your model ends with a 5, call 1-800-211-PANA (7262) to schedule service, they have a fix fuzzy the fuzzy colored spots they are covering under warranty.
Sep 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have small, fuzzy, gray spot in the same place on every photo. Nikon D40.
I would first try to clean the lense. If that does not work, swap lenses and see if it is in fact a problem with the lense or more with the body of your d40.
Aug 03, 2009 | Nikon D40x Digital Camera
On a gray screen a slight cloud like shadow shows,
the panel has a defect in that area.the panel
would cost more than you bought the tv for
Aug 02, 2009 | Samsung LN-T4665F 46 in. LCD Television
Gray cloudy spot in center of photos;distorted light streaks
Time for another. Sell yours to a repairman in an ebay auction, keeping your accessories, and buy a working used on without accessories cheap.
Or this may be a good time to either buy another TZ3 refurb w/warranty(90 days I think) or a new one one Ebay. They are very reasonable since being replaced with the newer TZ5.
Oct 12, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Blurry internet phot's
kindly brief your question again as i cant understand your question
Dec 03, 2007 | Computers & Internet
Panasonic Lumix DMC-LZ2 Digital Camera Logo
225 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
